-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   XBMC Android remote (http://www.hardwarecanucks.com/forum/htpc-systems-software/36885-xbmc-android-remote.html)
mattlef October 7, 2010 06:38 AM
XBMC Android remote
http://android-xbmcremote.googlecode...ers/v0.6.1.png
Well, this app is really cool.
It allows you to connect to your htpc via wifi and control xbmc with your android 1.6+ phone.
Has a tonne of cool features, and if you have a compatible phone, would do wonders for your media experience.
android-xbmcremote - Project Hosting on Google Code
Arinoth October 7, 2010 06:39 AM
How does this work, i haven't read into it. I imagine you need to download the plugin for xbmc and then the addon for android?
mattlef October 7, 2010 06:45 AM
In the new builds of XBMC there is an option for this remote that you must enable. You then download the Android XBMC app, type in the xbmc computers IP, connect to it and boom, there you go.
The instructions can be found here:
Setup_Instructions_9_11_and_later - android-xbmcremote - Setting up the remote with XBMC 9.11 final and later - Project Hosting on Google Code
botat29 October 7, 2010 06:52 AM
You don’t need plugin for the xbmc, just a server network setting and you simply enter the ip address of the xbmc in the setting of the android application and voila.
Arinoth October 7, 2010 07:56 AM
Well that was easy and straight forward. The only thing i dont like that is missing on the 'remote' is a volume control. Other then that its great, has every 'button' i need otherwise.
mattlef October 7, 2010 08:03 AM
the volume control on your device controls the volume of the xbmc.
Arinoth October 7, 2010 08:06 AM
Ah, well i have no complaints at all then :thumb:
botat29 October 7, 2010 08:25 AM
I install it...very nice. but I have a problem
http://www.hardwarecanucks.com/forum...de5feca816.jpg
first time I use XBMC, any idea how to fix it. ( my 7 is x64 )
