Old September 7, 2010, 09:02 AM
Bao Bao is offline
Default WIP: my ghetto HTPC/Gaming rig
Case: Lian LI PC-33
PSU: Seasonic M12D, 850W
CPU: i7-860 @ 4GHZ, HT-OFF (lower temps, don't need HT for what I use this thing for, but I'll probably re-enable it once the project is finished).
Motherboard: EVGA P55-FTW
Memory: OCZ3G1333LV4G x2 (waiting for 2000Mhz modules...)
Storage: OCZ Vertex2 Extended 120G
Optical Drive: External Asus Blu-Ray rom, just for installing the OS, and a few retail games, rather buy from Steam though.
Video: 2x Gigabyte GTX460 1GB @ 825/2050
Cooling: Corsair H50 ghetto mounted in the optical drive bay until I finish the project, push pull with 120mm Nexus fans.
2x 80MM Noctua fans for the exhaust, 1x 140MM Noctua case fan for air flow.
KB/Mouse: MS Sidewinder X8 Mouse, MS Wireless KB (waiting on Logitech's new wireless and backlit KB), Laptop Desk pad for increased comfort for PC gaming from the couch.
Laptop Desks, Laptop Stands & Laptop Accessories - LaptopDesk.net
A/V: Denon AVR 2307-CI
- lol got this in 2006, but it's still good enough for me. I only need 2 HDMI ports, and it supports LPCM over HDMI, so as long as the source can decode DTS-HD or True-HD then it's fine.
SVS 5.1 SBS-01 surround sound speaker set with the PB-10 sub woofer.
Sharp LC-52E77U LCD-TV, I really despise LCD's but I don't really trust plasmas for HTPC use either, so I went with this one, the good news is that it can be tweaked for very minimal input lag.
Plans:
1: I have no need for the optical drive bays, so I'll have them removed / cut out.
2: Mount the Radiator right at the top of the case where the optical drive bays have been removed.
3: Find a place for the SSD, probably use 3M mounting tape.
4: Drill new holes and have the 140mm fan moved "up" a bit to provide more air flow over the CPU area. The 2nd GTX460 runs pretty cool, as there are side vents in this case, so it doesn't really need additional air flow.
5: Dynamat or whatever solution to dampen the noise, applying to the bare areas and the top panel.
Sorry for the piss poor SE X10 pics:
Old September 7, 2010, 09:31 AM
lowfat's Avatar
Did you make that 140mm fan mount yourself?
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old September 7, 2010, 09:36 AM
Bao Bao is offline
Nope, it came with the case plus a decent 140mm fan.
The previous version of this system, was with a MATX EVGA P55 board using a Thermalright AXP-140, and for some reason I didn't buy a 140MM fan with it, so I used the Lian Li 140mm fan that came with the case, then later on I bought the Noctua fan to put back into the case bracket. I prefer the acoustics and performance of the Noctua. So when I did the ghetto mount with the H50 and new motherboard this past weekend, I kept the Noctua and shelved the Lian Li Fan.
Old September 8, 2010, 04:21 AM
DTI DTI is offline
Default HTGPC
Instead of leaving your H50 in your drive bays ,I believe these cases are the same Installed the ECO cooler like this
Just a Idea
Old September 8, 2010, 06:45 AM
Bao Bao is offline
These cases are very similar, and that was my original idea, but there's a big mess of cables there and with my H50 using two fans in P/P it might be even tighter. But yes your suggestion is way better than my idea of gutting out the 5.25 bays.
Did some measurements, with some work, a 360mm rad will fit.... going all out boys!
WIP HTPC(XBMC)/Server Rig Arinoth Case Mods, Worklog & Gallery 34 September 24, 2010 11:40 AM
Chucking together an HTPC from old rig Mr. Gruntsworthy HTPC Systems & Software 6 November 18, 2008 12:29 PM
New Rig - WIP misterlarry Case Mods, Worklog & Gallery 35 May 6, 2008 07:19 AM
Dual boot Xp Pro 32/64 on New Rig WIP misterlarry O/S's, Drivers & General Software 4 April 23, 2008 08:05 PM
Hillsdale's HTPC/ Overclocking Rig Hillsdale Case Mods, Worklog & Gallery 1 December 30, 2007 10:00 PM
