Old September 5, 2010, 05:54 AM
SKW's Avatar
SKW SKW is offline
Default What should I do?
Hello Guys,
I would just like to start by saying this is a great forum you got here. I have been reading the forum for a while but have never really posted.
I have been build gaming systems for years, but have never really built a HTPC/server like i am thinking about now. I have a couple of questions I would like to ask regarding software and hardware.
1. Is it a good idea to combine both a HTPC and server? The reason I ask is because i plan to put windows Server 2008 on it.
Thats the only question i had about software.
2. I plan to use a Silverstone Sugo SG02B-F Black SFF for this build. I have a P5LP-LE and a e6750. My question is would it be worth it to upgrade to a Gigabyte H55M-S2 and a G6950?
Thanks in advance for your help.
Cheers!
SKW
Old September 5, 2010, 08:00 AM
JD JD is offline
Your current hardware will suffice, just slap a HD4350 in there to get native HDMI output with audio.
And typically you don't combine server + HTPC as you normally want the HTPC to be as silent as possible, but you can make the server silent too. Depends what you need from it though.
I think things like XMBC or MediaPortal should run fine under Server 2008 (R2 I'm hoping?) though not sure you could use Windows Media Center.
Old September 5, 2010, 08:45 AM
Nope.
Old September 5, 2010, 04:23 PM
SKW's Avatar
SKW SKW is offline
i think i need a new video card tho... I only have a 8800GTS 320MB laying around.. what do you guys recommend?
Old September 5, 2010, 08:27 PM
JD JD is offline
HD4350 as I said above as long as you aren't gaming. Otherwise you'll probably want something like a HD5770 or HD5850.
Old September 6, 2010, 06:31 AM
Varroa's Avatar
ATI 5450 would be my choice. It will allow for HW acceleration in flash and VLC AND allows for cooler running and less power over a 4xxx series card.
GAMER: Win10 Pro x64, I7 8086K (corsair H110i), Asrock Z370 Taichi, EVGA GTX 1080 FTW, Gskill 4 x 8 GB DDR4 3200Mhz, Samsung 970 EVO 500GB M.2. NVME SSD, Western Digital Blue 1 TB M..2. SSD. Crucial M4 256GB, Mushkin 480 GB ECO SSD, HX750W, Sound blaster Z, & Phanteks Enthoo Pro M
Lenovo Ideapad Y510p: i7-4700MQ 2.4GHz (undervolted by 80mV), 16GB DDR3L-1866MHz, Intel GMA 4600HD / SLI'ed Nvidia Geforce GT 755M 2GB GDDR5, 240 GB Crucial SSD, 128GB M.2 SSD, 15.6" HD+ Glossy LED
Old September 6, 2010, 07:19 AM
SKW's Avatar
SKW SKW is offline
Default Video Card
I was looking them up on ncix. I am gonna get the XFX ATI 5450. Thanks for the suggestion.
