-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   XBMC/Network help (http://www.hardwarecanucks.com/forum/htpc-systems-software/34968-xbmc-network-help.html)
p3t3rson August 7, 2010 07:41 AM
XBMC/Network help
Started using XMBC for the first time. I have my mkv movies stored on my WHS. My HTPC is in my theatre room connected to my WHS using wireless-N. After installing XBMC it see's my mkv folder on my WHS. However it only recognizes one mpeg-4 movie thats in that folder. The remaining mkv movies are not detected. :censored: Can anyone tell me why?
Varroa August 7, 2010 08:14 AM
If you are going through the "media server" option in WHS then you may not be able to see the MKV files. Try using the "network Shares" option and you might be able to see them.
p3t3rson August 7, 2010 09:30 AM
I don't see an option for "network shares". when I add source I have my local drive, HDHomerun devices, Home folder, replay TV Devices, SAP Stream, and UPnP Devices. I was using UPnP Devices that then offers my the Windows Media Connect option.
Varroa August 8, 2010 06:14 AM
UPNP (or the media server as it is called) in WHS will not display video types that WHS cannot stream. I had the same problem with my WDTV Live and my WHS. The solution was to navigate to the network shared folders on the WHS and it would display all file types. Not sure about XBMC but there must be a way to view network shares.
Cheator August 8, 2010 08:40 AM
+1. Reason being is it usually does some transcoding before sending it off. What you have to do is allow the XBMC box to do it, and assuming its using VDPAU or DXVA then it should be fine for 1080p movies, etc.
p3t3rson August 8, 2010 06:14 PM
Got it to work! :bananafunky:
Thanks for your input Varroa, found a SMB network in XBMC that worked :punk: Now I need to wire my connection because the damn buffering thorough wireless is super annoying :angry2:
