-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   Ember Media Manager (http://www.hardwarecanucks.com/forum/htpc-systems-software/34506-ember-media-manager.html)
Arinoth July 24, 2010 11:18 AM
Ember Media Manager
Anyone able to get the trailers download thing to work? So far i haven't been able to get it to download a single trailer and i have all the correct options selected...
lowfat July 24, 2010 11:37 AM
I don't use a skin that allows trailers, so nope.
Arinoth July 24, 2010 11:38 AM
Transparency doesnt allow that? I think i may go with the default as i was liking how it looked over transparency (i like the extra info)
lowfat July 24, 2010 12:05 PM
Very few skins have trailers built in to then. Aeon is one of the few.
Realityshift July 27, 2010 02:16 AM
I think Alaska also allows for trailers.
YouTube - XBMC Pt 5 The Noobs Guide To Creating The Ultimate HTPC
Thats what I was using, seemed to work well.
Arinoth July 27, 2010 05:27 AM
I havent even heard of or seen alaska skin before
Realityshift July 27, 2010 10:06 PM
Its the skin im using on my MAG XBMC rig, looks amazing and runs MUCH better then any of the Aeons. Designed by the same make of Aeon (Hitcher).
Alaska - XBMC Community Forum
YouTube - Alaska - sep 24th preview
Its more muted, the overlays help with performance. Runs silky smooth on my Ion/Atom system and you can changed the color schemes.
YouTube - Alaska (XBMC) Trailer test
Arinoth July 28, 2010 07:59 AM
Did you use ember or xbmc to snag your trailers?
lowfat August 22, 2010 06:39 PM
I haven't used Ember in a while now and I forget how to use it... How do I scrape the shows automatically instead of doing each show by itself?
EDIT: For some reason the 'Scrape Media' button is blanked out for TV Shows. :blarg:
Arinoth August 22, 2010 06:48 PM
Uh... i would have to reinstall it on my computer to figure it out, tis on htpc which is packed away. Not sure if i was ever able to get it to do it for TV, hell even for movie.
