<~----> HTPC...for a tube TV? - Page 3 - Hardware Canucks
Closed Thread
  #21 (permalink)
Old July 14, 2010, 05:25 AM
Arinoth's Avatar
Originally Posted by headsh0t View Post
The S-video to RCA (well, video out) cable that came with my 6800gt worked fine on my 24" tube tv
For sound just run audio out to the receiver. That cable that Zero linked looks like it will fit the bill!
And to be fair to LionRed, it probably is a better idea buying one of those media players since the interface would be easy to use, it is tiny and takes barely any power and has all the connectors you need on it. You could easily get the money needed for it by selling those old parts. Although you can still make it easy enough for them by putting a single folder on the desktop titled "MOVIES", and you would also have all the regular functions of a computer...
That wasn't the adapter i was talking about. S-video to RCA will work because its essentially the same signal. What i was saying doesn't work are those passive vga/dvi to composite/component as nvidia doesn't give you access to switch the output video spectrum properly compared to ati allowing you to.
  #22 (permalink)
Old September 3, 2010, 01:59 PM
Be nice to your parents let them use the PC, J/k j/k
but srsly, you should test if the TV will take the signal or not first, I built an HTPC 2 months ago, only to find my TV won't take any signal weather I converted from DVI, VGA to component or RCA or even direct S video it was a 26" Pukasonic tube tv, the video card was a HD 46701gb.
I ended up just buying a new tv, because the VGA to RCA converter box i bought made this horriable line sometimes during movies.
  #23 (permalink)
Old September 3, 2010, 02:11 PM
BT!'s Avatar
BT! BT! is offline
i just went to NCIX for a link to this.. was just going to suggest the same thing, lol. you can stream right from your PC to it, or add a 2.5" hdd and use it as a file storage (movies and such). you could always sell some of your spare parts to buy one. i have one in the living room and it's my favorite thing i've bought in a long time. :)
  #24 (permalink)
Old September 3, 2010, 02:23 PM
Component and Composite both fall into the "rca" cable type.
Composite = R/W/Y
Component = R/G/B
Component -> S-Video -> Composite
Best bet is to use composite cables with a vcr as stated above.
  #25 (permalink)
Old September 3, 2010, 02:31 PM
The problem was solved two months ago. I don't know why this thread was even revived, but you guys can stop giving advice.
  #26 (permalink)
Old September 3, 2010, 02:59 PM
BT!'s Avatar
BT! BT! is offline
didnt even notice the date of the original post. also, the advice might be useful to someone else some day.
  #27 (permalink)
Old September 3, 2010, 03:05 PM
And that's exactly the problem. No offense, but people should really pay attention to the date of the posts in the thread before they go and reply to it.
  #28 (permalink)
Old September 3, 2010, 03:39 PM
BT!'s Avatar
BT! BT! is offline
someone bumped an old thread.. better call the forum police!!
  #29 (permalink)
Old September 3, 2010, 06:39 PM
Did someone call the forum police?
  #30 (permalink)
Old September 3, 2010, 09:20 PM
Arinoth's Avatar
Thread locked, people really should be looking at post dates and stop thread resing unless it was a subject they themselves had issues with that re-occured or had the same issue and the op had no resolution to begin with
Closed Thread
[FS] Little Dot II Tube Amplifier Wankerfx Buy/Sell & Trade 8 May 26, 2009 07:48 PM
How long does TIM last in the tube? thenewguy001 Air Cooling 6 January 15, 2009 06:28 PM
Tubing and Tube Coils miggs78 Water Cooling 21 August 16, 2008 06:51 PM
What tube is this? biff Water Cooling 4 February 1, 2008 10:30 AM
How to remove the air inside tube? francois methot Water Cooling 18 August 6, 2007 07:23 AM
