HTPC Keyboard/Mouse suggestions? I am currently using the Lenovo Multimedia PALM-SIZED Mini Wireless Keyboard and Track Ball Mouse 2.4GHZ 10M USB Remote for my HTPC and so far it kinda sucks. No backlighting, distance sucks and poor layout for Shift, Caps, Delete and Backspace buttons. Anyone with suggestions with something they are happy with? |
What OS are you running? I have tried a couple of wireless keyboard/trackball/trackpad combos and they are all just OK. There are a few apps for the Iphone that turn your Iphone into a remote as well. |
I am running Win 7 Ultimate 64-bit. I thought about an iphone app but then my wife can't use the HTPC when I am not around. |
The dinovo mini has a great layout but it was designed stupidly. When you hit the backspace key the back lighting shuts off. Besides that, it is great. I am currently using a Rii Mini, which sucks. Arrow keys are horrible. Plus unlike the Dinovo you can't really two hand it for XBMC. Everything is almost done w/ the right hand. YouTube - Rii mini wireless keyboard (Worlds smallest wireless usb keyboard w/touchpad) second look |
im using the enermax aurora wireless keyboard for my htpc and so far its been flawless... distance is good and i like the finish on it... i also use the dinovo mini as backup but mostly for my ps3 |
I am using this little monster ( with the remote it's kick ass ) NCIX.com - Buy Nmedia Black Wireless Keyboard & Remote Combo RF 2.4GHZ 40 Feet with Trackball - HTPCKB-B In Canada. The mouse is a track ball that is on the remote and on the KB. Range is nice and KB is good. If you want something more classy there is the Dinovo Edge from logitech with a track pad or the Dinovo Mini NCIX.com - Buy Logitech Dinovo Mini MCE HTPC Wireless Keyboard Backlit Bluetooth 30FT Range LI-ION - 920-000595 In Canada. NCIX.com - Buy Logitech Dinovo Edge Bluetooth Ultra Slim Wireless Keyboard Rechargeable LI-ION W/ USB Mini Receiver - 967685-0403 In Canada. The dinovo edge is nice since it's a rechargeable keyboard. If you want to buy a blutooth adapter then you can get this one Cordless MediaBoard Pro? for PSŪ3 |
I'm using a IOGear keyboard with built in trackball IOGEAR WIRELESS 2.4GHZ KEYBOARD,ERGONOMIC,TRACKBALL |
If you can afford it, get a logitech dinovo edge. They also have a cheaper on bluetooth for PS3, I highly suggest against it (don't support Console markets). That one also has a bunch of buttons that can only be used on a PS3 (no native remapping), and there is no 'windows' key. |
| All times are GMT -7. The time now is 01:13 PM. |
