Old July 4, 2010, 04:43 PM
biff's Avatar
Default Can't get spdif out on ga-ma78lm-s2h
I trying to get the spdif going and can't find anywhere to enable it or select it as the default output device. I can only select realtek HD audio for output.... oddly I do have a spdif option but for input only. The manual is no use, and the screen shots they have is different then what I'm looking at anyway. Any ideas?
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old July 4, 2010, 05:11 PM
TopDogZero's Avatar
Strange, my son has a board with Realtek and the digital output (optical) option shows up under both the Windows and Realtek control panels? I'm assuming you have the most recent driver from the Realtek website.
Old July 4, 2010, 05:50 PM
biff's Avatar
I've got the latest drivers from GB, I didn't try getting drivers from realtek but I get an error when I try to download from their site right now. BTW What are you using for an adapter to the header on the mobo?
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old July 4, 2010, 06:28 PM
TopDogZero's Avatar
My son's board is an Intel chipset just to make that clear, I don't have any thing plugged in to the header on the board as there is already an spdif jack on the I/O panel. In the Realtek and Windows audio panels there are 2 digital out's one marked optical, I'm guessing the other one is for the header on the board.
The Realtek HD Audio output option your getting is IMO for the HDMI output as I think the HD 3200 has a built sound codec.
PS. I remembered guys having problems with AMD video cards and on-board Realtek codec, because the AMD cards have it's own Realtek codec (Realtek HD Audio), basically the drivers which are not the same would interfere with each other so one of the 2 would have to be disabled.
Now I'm not sure how it works on your board, are they using the codec in the HD3200 or is there another one for the spdif? Need someone with more knowledge of AMD boards.
Digital sound with .mkv files via SPDIF Hunt Audio 6 February 26, 2010 07:15 AM
spdif in to analog 5.1 out? undacova Audio 5 August 10, 2009 10:35 AM
Optical SPDIF cable SugarJ Audio 13 November 19, 2008 11:42 PM
