Old July 5, 2010, 08:26 AM
Arinoth's Avatar
Well i'm slowly doing this with my movies, the ones that are the 480p i like, then going to do the divx/xvid ones i'll eventually be replacing then use tvrenamer. Hopefully i get my htpc by the end of the week (from ncix and the hsf from someone on here) and get it up and running by my birthday.
Here I am: here I remain
Old July 8, 2010, 04:58 PM
Arinoth's Avatar
Looks like i wont be able to get this up and running until after the weekend unless canada post pulls a miracle and gets it here for tomorrow. Should i run Windows 7 or Windows Server 2008 for my htpc/server/torrent box (keep in mind i want to remote access/connect to it and that i have a copy of windows server for free thanks to msdnaa)
Old July 9, 2010, 03:39 PM
lowfat's Avatar
I use Win 7 HP. Although I don't use RDP. I just use VNC.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 9, 2010, 04:21 PM
Arinoth's Avatar
Uh can you spell out those acronyms, you got me lost
Old July 9, 2010, 04:40 PM
lowfat's Avatar
Home Premium. Remote Desktop Protocol. Virtual Network Computing.
Queen of Dreams WIP
Big Lian Li
Complete
Old July 9, 2010, 04:56 PM
Arinoth's Avatar
Virtual Network Computing allows me to do what?
Old July 9, 2010, 04:58 PM
lowfat's Avatar
VNC allows easy fast remoting in to another computer on the same network.
Doesn't matter the platform either.
Virtual Network Computing - Wikipedia, the free encyclopedia
Queen of Dreams WIP
Big Lian Li
Complete
Old July 10, 2010, 07:10 AM
I prefer VNC for a HTPC. The windows RDP will close the distant session if opened when you connect, unlike a VNC application (or most of 'em.) + You can't connect with RDP on a windows home edition. (well, it is not set up out of the box, Don't know if you can add it). But as you got an MSDAA, should'nt be a problem. Also, VNC is easily usable cross-platform with linux, and probably mac too. If your going to use windows, you may just use Win7. It's all fine for what you need to do.
  #19 (permalink)
Old July 10, 2010, 09:01 AM
awesome little prog. used it for years..i like the fact no install needed for viewer.exe to access the server
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
  #20 (permalink)
Old July 16, 2010, 05:35 AM
vnc on linux? ew... ssh ftw :)
heat
rfd
hofo
Zotac MAG XBMC box Realityshift HTPC Systems & Software 17 July 3, 2010 12:02 AM
XBMC wifi p3t3rson O/S's, Drivers & General Software 1 March 9, 2010 11:37 AM
Ultimate HTPC Software Guide (XBMC,MPC-HC,bitstreaming, ripping blurays) lowfat Guides & How-to's 16 January 28, 2010 07:49 AM
XBMC start with Windows? Cypher^64 HTPC Systems & Software 6 September 21, 2009 06:56 PM
XBMC in all its beauty. lowfat HTPC Systems & Software 27 September 18, 2009 05:22 PM
