Old June 27, 2010, 08:44 AM
Originally Posted by Arinoth View Post
Have you tried XBMC for Windows (xp, vista or 7)?
I tried it on Win7. It works quite well. I was doing some test with XBMC on my laptop on Linux and it was very slow and navigating in the menus was a pain, but on my desktop and with win7 it's just fine, there's a better driver support , but the PC has some more horsepower too -.- The GUI is really nice.
Old June 27, 2010, 09:04 AM
i used it aswell with xp and win7, it worked very well on my 5200+ & 1gb ram ..excellent for streaming movies instead of dl'n them..
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old June 27, 2010, 09:13 AM
Arinoth's Avatar
I may go that route as there may be some extra things i'll be using with this htpc/server that i know has drivers/works in windows but unsure about in linux. To name a few usb to controller adapters, 20x2 lcd screen in case, my 'olderish' wireless remote for pcs that came with my x1900 back in the day, and remote connection/pc.
Here I am: here I remain
Old June 27, 2010, 11:29 PM
Realityshift's Avatar
The MAG doesnt support lossless through HDMI but I believe it does through the optical out, I may be wrong.
It is actually easier to get XBMC to run smoothly through minimal linux on alot of applications, and I find with the alaska skin installed menu performance is pretty much lag free on the ATOM/ION builds. I highly recommend this skin, hitcher, the creator, made it as the anti aeon skin, its as minimalistic as you get yet it incorporates more in the way of flagging and video information the aeon did, and adds alot more and looks so much better then the stock confluence skin.
The Builders Hammer
Old June 28, 2010, 12:40 PM
r0bc's Avatar
I really wish it did but I'm pretty sure it won't do DTS HD MA/Dolby True HD MA.
I wanted to get one awhile back because its the perfect size/price for what I need but in the end I just put together a cheap i3 box. I'd still buy one if I found out it did DTS HD MA/Dolby True HD MA, but I read acouple places it didn't. I think maybe Anand even mentioned it in his review.
Old June 30, 2010, 03:56 PM
Well personally its probubly not a feature ill ever need, this was more of a dirt cheap alternative, something that will probubly only see a 42" 1080p tv with HT in a box for my parents and for this it excels completely.
The Builders Hammer
Old July 2, 2010, 12:56 AM
lowfat's Avatar
You could always just build an i3 itx system if you are looking to bitstream.
Mael
Big Lian Li
Forever Alone
Old July 3, 2010, 12:02 AM
r0bc's Avatar
I did,just a cheap box nothing fancy.
I looked at the Dell Zino HD also but same deal with audio.
This case got a 10 in Maximum PC Mag. cdn_Madrach Reviews & Articles from the Web 14 December 16, 2011 11:15 AM
XBMC wifi p3t3rson O/S's, Drivers & General Software 1 March 9, 2010 11:37 AM
MAG (I'm having mic issues with my BT set) Cadence Gaming 0 January 28, 2010 07:14 PM
XBMC start with Windows? Cypher^64 HTPC Systems & Software 6 September 21, 2009 06:56 PM
XBMC in all its beauty. lowfat HTPC Systems & Software 27 September 18, 2009 05:22 PM
