Old May 10, 2010, 05:12 AM
TimTheEnchanter's Avatar
Ok, will take some as soon as possible, but it may take some time, i've got work + summer class and it's keeping me away from home from 7h00am to 10h30pm.
Old May 10, 2010, 08:29 PM
biff's Avatar
Originally Posted by feerof View Post
pics please =) i have a friend that wants an HTPC but i don't know where to start
Kind of depends on what he wants to do with it. Mine is primarily for media playback, music and BDs and really you don't need much at all. Min has a E3110 (same as a e8400) and playing BDs the cpu usage is in the single digits so I'm sure a much lesser cpu would work just as well. I have a 4670 which offloads alot from the cpu. AFAIK even a lowly 3450 will do the same and TBH I don't know if I'm getting any benefit from having a card better than that. For audio you can just output digital from the onboard sound and get a good used receiver for probably less then a 'good' sound card that will do the decoding. Using 5.1 over s/pdif or digital coax is going to be compressed but it's really not that bad. I could be wrong here but I think by the time you're realizing the limitations of the compressed 5.1 you've got some pretty good speakers and associated audio equipment that going beyond a super-budget HTPC is still going to be pretty cheap in comparison.
Just my 2 cents.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
[WTB] CHEAPO POWERSUPPLY FOR TESTING sinticfury Buy/Sell & Trade 7 August 20, 2009 08:33 AM
Cheapo Cooler Bay Mod dosmond Cases 1 July 11, 2009 09:09 PM
HTPC OS? biff HTPC Systems & Software 25 February 26, 2009 06:09 PM
Cheapo vid card recommendation biff Video Cards 11 September 23, 2008 08:45 PM
which cheapo vid card? philmar Video Cards 6 May 25, 2007 03:46 AM
