Old October 13, 2007, 04:26 AM
Default TV Tuner to rec digital feed
got a question about Tv Tuners recording Digital cable
WinTV-HVR-1800 is a dual tv tuner with one being analog the other being digital. My question is will it decrypt Videotrons Digital signal so I can record and watch digital feed from my PC.
WinTV-HVR-1800 Product description
Or will the Wintv HVR1600 do the same? is there a huge difference between the 2? or is it even noticeable?
WinTV-HVR-1600 Product description
Or is there somthing better out there?
Dont have alot of TV tuner knowledge. But If I could find a better solution then buying Videotrons Extremly over priced PVR (500$) I would be a pig in S*** lol
Intel E6550 / Gigabyte GA-P35-DS3L / Corsair CM2X1024-6400C4 x2 / Segate 320Gb / PNY 8600 GT ddr3 256MB / Coolmaster CM690
Last edited by Wiked; October 13, 2007 at 04:32 AM. Reason: cause I can with out double posting
Old October 13, 2007, 11:36 AM
Misoprostol
Guest
Posts: n/a
Until Canadian cable companies are forces to support cablecard, we're f***ed.
You have to either watch in SD, or buy the PVR from your cable provider.
Old October 14, 2007, 11:18 AM
Robscix's Avatar
Can't you just connect the RCA OUT's form the Digital Decoder Box to the Video in present on many video cards and TV tuners?
Old October 14, 2007, 12:04 PM
Misoprostol
Guest
Posts: n/a
He wants something that will *decrypt* the digital signal. Unfortunately this will not exist until the Canadian government passes legislation that FORCES the cable companies to allow it.
Old October 14, 2007, 12:40 PM
Robscix's Avatar
Yeah I kind figured that after I posted. It would be nice to do such things.
Our boxes here in Canada don't use cards. I am pretty sure, every one has a unique number and they turn it on or off using this method. I was interested in something of this nature but looking at the Digital satellites instead.
riva tuner lcdguy Video Cards 0 March 3, 2008 01:20 PM
Help with ODIN's Power Tuner Malam Power Supplies 18 January 9, 2008 09:22 AM
Poor picture quality from TV tuner Sharkylegbreaker HTPC Systems & Software 7 November 29, 2007 02:03 AM
TV tuner/Capture card the_bandit87 Video Cards 2 November 14, 2007 11:16 AM
Need a good TV Tuner for an HTPC Misoprostol HTPC Systems & Software 18 May 15, 2007 01:52 PM
