Old October 10, 2007, 09:53 PM
Default Questions and Recomendations
Hello all,
Im new here, just found out about the site today. Anyways, I am looking to get my Bell Express Vu hooked up to my computer so that I can watch/record tv on it. This is also my main computer that I will be using. Im looking at getting Beyond TV with the PVR-150, but I need a sound card, Im just using onboard for now. I am looking at the Sondigo Inferno because of the connections it has. I do play games like FSX, Bioshock, Half Life 2, etc...What I would like to do is have optical sound from the Bell reciever to the Infernos optical input and use that for sound and the PVR-150 for video input. Will I beable to record without problems with this setup?? Also, how is the Inferno with the games I play. Any other sound cards I should look into for what I want to do?
Old October 10, 2007, 10:29 PM
BALISTX's Avatar
What is your budget for a sound card?
You can go the higher end of the price scale such as the
AuzenTech X-FI Prelude 7.1 Sound Card PCI 32BIT Eax 5.0 - $199.99
ASUS Xonar 7.1 Channel PCI Sound Card 24BIT DTS Dolby Digital S/PDIF IN/OUT 118DB Snr - $194.99 - We have a Review on it here.
or you can lower end of the price scale
HT Omega Striker 7.1 7.1 Channel PCI Sound Card 24BIT DTS Dolby Digital Live S/PDIF IN/OUT Coaxial -$79.99
Sondigo Inferno 7.1 Channel PCI Sound Card 24BIT DTS Dolby Digital Live S/PDIF IN/OUT - $84.99
Heatware
HWBOT
Old September 20, 2008, 09:25 AM
Originally Posted by Brando737 View Post
Hello all,
Did you get it set up? I am having trouble with Express View and Vista 64bit media center. It does not recognize any signal. I am using a WinTV-HVR-1800 card.
Thanks
Please Help~answer the questions> < dracozhu Troubleshooting 6 March 8, 2008 03:17 PM
Partition Questions mattydies Storage 6 December 23, 2007 05:57 PM
Cooling questions... Jaret Water Cooling 35 December 11, 2007 06:48 PM
Some questions about F@H qwerty HardwareCanucks F@H Team 4 October 16, 2007 06:45 PM
some questions about the pc... omgwtf CPU's and Motherboards 17 August 17, 2007 09:44 PM
