-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   single core HTPC? (http://www.hardwarecanucks.com/forum/htpc-systems-software/27944-single-core-htpc.html)
mo' power January 18, 2010 07:48 PM
single core HTPC?
Greetings all. I was wondering if the following would be ok for a HTPC build.
P4 s775 3.2 Ghz
4GB pc6400
1TB hd
HD 4650
HTPC case
Auzentech sound card
HTPC case
400-500W psu
matx mb (intel) that will accept just about any s775 cpu
logitech cordless elite kb (currently retired)
I'm going for a really low-cost HTPC. I was rooting through the recycling cage at work and pulled the cpu from a Dell. I also have the HD4650 on hand. I'll definitely add a cpu cooler to squeeze out some extra Mhz. Any suggestions for the cooler, case and psu would be appreciated. This will be built hopefully before summer. Thanks
As this is my first htpc build I'll be reading your posts and asking questions (mostly software) Thanks.
Perineum January 18, 2010 09:02 PM
It will definitely work. 2.0ghz socket 754 AMD with 512 does the job easy...
MAK January 19, 2010 12:47 AM
I am using a Pentium 4 3.2Ghz in one of my older HTPCs, and it is running great. A real pleasure to use. But I think you will be surprised when you get it running: The 3.2 Ghz Pentium 4 processors had Hyper-threading technology, which makes the processor work as a virtual dual processor or dual core system.
Under device manager, I see two pentium 4 CPUs (ACPI Multiprocessor PC) running in that HTPC.
ZZLEE January 19, 2010 01:20 AM
ASUS P5Q
I have an Intel P4 3.0 double threded running on an ASUS P5Q Motherboard. It is used fore email and photo printing and storage space. Runs fine
ZZLEE January 19, 2010 01:33 AM
Dont Know fore sure
Newegg.ca - ASUS P5KPL-AM EPU LGA 775 Intel G31 Micro ATX Intel Motherboard - Intel Motherboards
Dont know fore sure that this will suport your prosessor, My ASUS P5Q does fore sure
kingnubian January 19, 2010 09:23 AM
These days HTPC's are more about vidoe card hardware acceleration capabilities than cpu speed. Look at the popularity of the Nvidia Ion platform which mates an Atom processor to a very capable GPU. The Atom is no thoroughbred by any means but these system can play 1080p without a hitch.
The only time that cpu power comes into play is with HD non supported video formats which gpu's hardware acceleration has no support for. This is becoming the exception & not the rule.
Your HTPC looks fine to me. Any low cost quality S775 board that supported your cpu & has a Pcie (Preferably 16x but not necessary actually) should do.
mo' power January 20, 2010 05:25 AM
Ok. Now that the hardware has been taken care of, how about software? I plan on running XP sp2 on it. Because XP doesn't have a media centre, is there some sort of media centre software I can use similar to the vista or windows7 media centre? I'd prefer free. I would just like to have similar functions and some sort of interface for retrieving media.
I am also curious to know what media players you are all using. I plan on using the k-lite codec pack.It has served me well over the years.
Arinoth January 20, 2010 06:35 AM
I would try to see if you can run windows 7 on it. Only reason i say this is i've notice that Windows 7 boots faster then xp, it doesn't seem to 'hang' as much when it gets near full load and that it just responds a lot better/faster when running a few programs. This is from my own tests using my N330 Atom Dual Core Processor with Hyper Threading enabled OC'd to 2.0GHz (similiar tests were done on both OSs at same OC) with 2GB of ram.
I would stay away from vista as if it were the plague for a htpc.
MAK January 20, 2010 06:50 AM
Actually, Windows XP did have a media center, you just had to buy the special version (Windows XP Media Center Edition). That's what i have on my old HTPC. It runs great.
And I agree: avoid Vista, go with either Win XP MCE 2005 or Windows 7.
mo' power January 20, 2010 07:57 AM
I already have XP on hand. I'd rather not go out and buy another OS. I just ditched my vistagarbage for win7 oem premium and my gf is going to make the switch from win7 RC to oem premium in the next few weeks. I'm sure there must be some free or relatively cheap mc software out there somewhere. Otherwise, I'll stick to the old-fashioned music, videos and music folders. If all goes well, I should have my 120hz 40" sharp aquos by the end of march.
