-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   First Time HTPC (http://www.hardwarecanucks.com/forum/htpc-systems-software/27860-first-time-htpc.html)
PC_Commando January 16, 2010 06:58 PM
First Time HTPC
I'm looking for advise on building a media pc. I will be connecting to a 32" Samsung LCD TV. I will eventually be playing Blu-Ray movies on it but that will come later. My budget is $500 including taxes and shipping.
This is what I have come up with so far.
AMD Athlon II X4 620 2.6GHz
Gigabyte GA-MA785GMT-US2H
G.Skill F3-106666CL8D-4GBRM Ripjawas PC-10666 4GB DDR3-1333
WD Cavair Blue 500GB SATA2
LG GH24LS50 24x SATA DVD±RW
OCZ StealthXStream OCZ400SXS 400 Watt
Price: $415.71 before taxes
Shipping is free from Direct Canada
Everything else (keyboard, mouse, remote control, case, Windows 7 Ultimate 64-bit, wireless NIC) I have
Do you think the quad core processor and 4GB of ram is overkill?
Perineum January 16, 2010 07:07 PM
I would say ditch the quad for and get the 550BE, it's 3.1ghz dual core which would probably make more sense. As a side bonus I've been unlocking them (which is supported by the motherboard you have picked out) and turning them into quad then overclocking them to 3.8ghz.
RAM is overkill too, but I typically purchase lots of RAM so I wouldn't necessarily ditch it, especially if you're within your budget.
lowfat January 16, 2010 07:14 PM
Core i3 530 $130
Gigabyte H55M-S2H $94
2GB Geil DDR3-1333 $65
500GB WD Green - $53
CORSAIR CMPSU-400CX $60
+ any random $25 DVD drive
$10 or so more. However if you want good bluray playback this is the way to go. It is one of the few ways to bitstream audio and it most definitely is the cheapest.
PC_Commando January 16, 2010 07:48 PM
What about the Intel Pentium Dual Core G6950?
Perineum January 16, 2010 07:54 PM
That's an interesting build lowfat. Never priced it out but didn't think it would come in that cheap.... I think AMD is in trouble.
lowfat January 16, 2010 08:28 PM
That would work as well I suppose.
Comes out to $425. I just forgot to post the links. But I grabbed all the prices from shopbot.ca
kendallcschm January 16, 2010 08:32 PM
i agree with you.. i think the dual core or a higher speed triple core are better ways to go.. especially since they unlock into quad cores.. :-P
Perineum January 16, 2010 08:47 PM
Yeah, but really hard to ignore that socket 1156 build that lowfat pointed out.... now I'm curious how powerful the on-cpu-video is...
PC_Commando January 16, 2010 09:08 PM
I'm curious as well. I'm going to research that.
lowfat January 16, 2010 09:14 PM
Core i7, i5 & i3 LGA1156 Processors Thread: Clarkdale Supports HD Audio Bitstreaming! - AVS Forum Massive thread can be found here
