Old January 3, 2010, 11:06 PM
biff's Avatar
Originally Posted by jdrom17 View Post
At the most on Intel's side, E5200. Don't need anything above that. Though I'd imagine the E3200 would be plenty too.
Something like this would do: NCIX.com - Buy NCIX Value Bundle Deal Intel Pentium Dual Core E5200 Gigabyte G41M-ES2H & Kingston 2GB HyperX RAM - G41-E5200-2GB In Canada.
I'd probably toss in a HD4350 as well since I'm not too sure how good Intel outputs HD.
Geez I was gonna say that's a little bit of a rip off since the mobo and CPU can be had for ~$137 but apparently DDR2 is getting a bit pricey now.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old January 4, 2010, 03:03 PM
JD JD is offline
DDR2 and DDR3 prices are about equal IMO. If you can afford the little extra an AM3/DDR3 motherboard costs, then you might as well go that route.
Old January 4, 2010, 08:25 PM
biff's Avatar
Yeah not saying you're wrong, Just I remember DDR@ being dirt cheap at one point. Bought 2GB of some pretty good stuff for ~$16 or $17 a bit back so seeing NCIX alot $60 -$70 for RAM in that package deal threw me back but that is what it's worth now.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
Old January 4, 2010, 09:14 PM
Dazmode's Avatar
I have i5750/P55 board HTPC. Works fine with 53" TV with HD4870 card. Before that i had dual core 2Ghz with HD2600 and it worked the same as i5 set up.... Ijust under XP ... it couldn't handle Vista or 7. I recommend Antec Fusion 430 as a case (good cooling), just replace fans with better ones... GELID Thermal Controlled fans worked for me. Good sound card won't hurt either.
Orange Build: Final Video
HTPC Build: Final Video
Old January 17, 2010, 04:41 PM
Hi guys,
I just wanted to thank you all for your input . I was going to build my own system, but ended up buying a complete
system from Future shop.
It's not the best system out there, but so far it is doing everything I need it to do with no headaches.
I bought a Hewlett Packard P6218F . It cost me $580 .
The determining factor for me was that Windows 7 was included. That was a $200 cost to me if I were building my own system.
The video card has HDMI output to my tv, and has worked flawlessly so far.
To build this system from scratch would have cost me in the $800 range. I know all the components aren't the best
but so far the machine is doing everything I need it to do.
Again many thanks for the responses.
Cheers,
Craig
Old January 17, 2010, 04:44 PM
Also,
I bought a Logitech Di Nova Edge keyboard.
I have mixed reviews on it at this point, but I'm starting to get used to it.
Cheers,
Craig
1000$ build belinik New Builds 17 December 10, 2009 08:36 PM
1000$ Budget Build Snoopy484 New Builds 13 June 1, 2009 06:55 PM
Build me a quite PC for $1000 min New Builds 23 March 28, 2009 12:45 PM
$1000 Build For a Friend geokilla New Builds 19 February 21, 2009 06:56 AM
Build my PC! (Around $1000.00) philthygeezer New Builds 57 October 31, 2008 01:40 PM
