-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   Windows 7 compatible Tuner card (http://www.hardwarecanucks.com/forum/htpc-systems-software/27217-windows-7-compatible-tuner-card.html)
shinysuitman December 30, 2009 01:56 PM
Can anyone here recommend a good HD tuner Card that will work well with W7 and the Media Center. I really would like something stable. Last time I tried getting a wifi card I tried several models and I ended up just buying a long cable. My budget is sub 200 dollars. Dual tuners would be nice too.
