Originally Posted by lcdguy Since i use a projection system my "TV" does not have an ATSC tuner. My question is do i get an ATSC tuner for my HTPC or do i just get a setop tuner or a network enabled ATSC tuner. They would all cost around the same price (130-170). |
Good question. If you're going to use it for OTA signals, I'd go with the ATSC tuner for the HTPC. An average one would be something like the Hauppauge HVR 1600 or if you can get the dual tuner one (the 2250), you'd have two tuners (watch one while the other is recording).
I've used all three methods. The network enabled one (I have the Silicon Dust HD Homerun) seemed at the time to be the most flexible, but after connection issues I finally had to isolate the HDHomerun on its own little network which meant I needed two network cards in the htpc: one for data and Internet, and the other exclusively connected to the subnet containing the HD Homerun (video network). A pain, but now the HDHomerun (on one htpc) and the Hauppauge (on another) record equally well.
A set-top would be great if you are going to connect to a cable company (like Rogers) or sattelite (Bell), and I'd recommend just getting a good PVR that works for that and bypassing the htpc. But a set-top tuner for OTA HD signals is kind of a waste.. the other two solutions connect to your htpc and allow you use it as a PVR and record HD etc..
