Here's my scenario (with diagram at the end of the post):
My PC (blue) is basically in direct line of sight from the TV (purple) in the basement (about 15-20ft). However I'd rather not run the cable directly to it since then it would run in the middle of the floor. So, luckily the other side of one of my walls faces into the furnace/laundry room (light purple) which isn't drywalled so running a cable (orange) through there is simple. Green lines are doorways.
Only thing I'm wondering, is the HDMI output on my HD4890 Vapor-X (native, no adapter) going to output enough power to get the signal down that 40ft piece of cable? Needs to send 1080p video along with audio. Interference wise, shouldn't be too bad, and I'll do my best to keep it away from the electrical wiring.
And the cable in question is this
22AWG cable from Monoprice or the
24AWG if you think it would also work alright. 24AWG is preferred since it would be a bit more flexible and it's $10 less, but I don't want the signal to be degraded when it gets to the TV.
I'd also be using
one of these port savers at each end since I imagine either cable is going to be heavy and not overly flexible.
