Old December 13, 2009, 03:07 PM
BrianHanna's Avatar
Default How do you make a PVR?
i've been thinking about making a media center for my home.
i know it would be pretty simple to make a device that plays blu-ray, connects to internet etc.
but what about making it a pvr as well?
how do i go about that, what do i need, what kind of software would i need for it to record certain programs at certain times, etc?
this is what i have so far picked out if i make it.
NCIX.com - Buy Nmedia HTPC-1000B Desktop Media Centre Case mATX Black 1X5.25 4X3.5INT Card Reader No PS - HTPC-1000B In Canada. case
NCIX.com - Buy ASUS P5KPL-CM mATX Intel G31 LGA775 1PCI-16 1PCI-E1 2PCI SATA2 Video Sound GBLAN Motherboard - P5KPL-CM In Canada. motherboard
NCIX.com - Buy Intel Pentium Dual Core E5200 Dual Core Processor LGA775 2.5GHZ 800FSB 2MB Retail Box - BX80571E5200 In Canada. cpu
NCIX.com - Buy Corsair XMS2 TWIN2X2048-6400C4 2GB 2X1GB PC2-6400 DDR2-800 CL 4-4-4-12 240PIN Dual Channel Memory - TWIN2X2048-6400C4 In Canada. ram
NCIX.com - Buy XFX Radeon HD 4670 750MHZ 1GB 800MHZ DDR2 2XDVI PCI-E Video Card - HD467XZDF2 In Canada. Gfx
NCIX.com - Buy Western Digital WD10EADS Caviar Green 1TB SATA 32MB Cache 3.5IN Hard Drive OEM - WD10EADS In Canada. hd
Asus p6x58d-e / i7 930 @ 4ghz / G.skill 1600mhz 2x3gb 9-9-9-24 / Corsair TX750 / XFX HD 6850 1GB x2 @ 870/1070/ Coolermaster HAF 932 / Noctua nh12-up / Western Digital 500g Caviar black /Western Digital 1TB Caviar black 60Gb/ Seagate 7200.11 500g / OCZ Vertex 3 SSD / Samsung 2253BW / G5 / MX518 /
Old December 13, 2009, 03:14 PM
gingerbee's Avatar
and some software and your rocking NCIX.com - Buy Diamond All in Wonder Aiw Radeon 3650 Premium 512MB DDR2 DVI HDMI Video Card W/ IO Board Remote - AIWHD3650PM In Canada.
just so you have options here's other tv tuner cards NCIX.com - Canada's Premier Computer Store - Great Technology, Service and Selection.
Old December 13, 2009, 03:17 PM
MarkOne's Avatar
after jungle with all those free software , I purchase this one
Shaw Direct (Star Choice) DSR530HD [HD-PVR/Mpeg-4] @ Kusat.com
so my Hauppage is useless
Old December 13, 2009, 03:58 PM
lowfat's Avatar
My vote also goes for getting a provider's PVR. Especially for HD. The Hauppauge HD PVR is pretty shitty.I really wish I didn't spent $350+ on it and software for it.
Old December 13, 2009, 04:05 PM
MarkOne's Avatar
Originally Posted by lowfat View Post
.....The Hauppauge HD PVR is pretty shitty.I really wish I didn't spent $350+ on it and software for it.
I was close to try one before I order my StarChoice PVR..... the Hauppauge I have is only a tv card
Old December 14, 2009, 10:08 AM
BrianHanna's Avatar
k, ill look into that
Old December 14, 2009, 11:53 PM
HaDeS
Guest
Posts: n/a
Yep by the time you spend the money on any tv tuner card that supposedly does HD you could have purchased your providers PVR. However if you don't need perfect quality hd on your computer than the haup cards will do just fine... you can store a lot more data on a computer than you can say a star choice pvr. The question is how often do you re-watch recorded content?
HD-PVR & ShawDirect slay3r HTPC Systems & Software 18 December 8, 2009 07:33 AM
PVR f4ngtooth Off Topic 0 September 18, 2008 06:29 PM
HELP ! Xfi + hauppage pvr 150 matsta31 Audio 8 September 6, 2008 04:57 AM
Access motorola pvr/dvr killerklown Off Topic 0 March 15, 2008 12:43 PM
Adding Extra Drive to Rogers PVR Malam HTPC Systems & Software 0 January 16, 2008 09:22 PM
