Old December 1, 2009, 09:42 AM
Default Live TV recording
I am using HD-PVR as tv tuner + SageTv. Can the constant live tv recording be bad for a drive? Would I notice a difference between Green and Black caviar while watching live tv on my htpc?
Old December 1, 2009, 09:46 AM
lowfat's Avatar
Drive will be fine. And no you won't notice a difference between a Green and a Black. You are only writing/reading 3-4MB/s.
Old December 1, 2009, 10:26 AM
artistpavel's Avatar
I'm using WD Green and SageTV, sometimes I have TV on all day, no problem. I believe SageTV records Live TV to the same location you store shows, I would be concerned if it was recording to my main SSD drive.
Old December 1, 2009, 11:38 AM
Are the recording reducing the lifespan of the hard drives? Like a SSD?
I wanted to buy either the 640 black caviar or 1tb green and give a 200gb partition for O/S and the rest for live recorrding, recorded shows. I will store the shows i want to keep on another backup Green drives.
If there is not advantage for black on htpc then I will go green
Old December 1, 2009, 12:58 PM
Green is cooler and making little or no noise.
Watching Live TV on SSD would shorten the lifespan of it.
Old December 4, 2009, 12:21 PM
Alright ty
Recording HD from STB biff HTPC Systems & Software 12 May 22, 2009 12:26 PM
Recording with DV Camcorder Jonwall O/S's, Drivers & General Software 2 April 15, 2009 07:27 PM
What soundcard for recording? Dr_BenD_over Audio 10 December 3, 2008 07:09 PM
New Recording Card From Auzentech Robscix Audio 10 October 19, 2008 08:49 AM
Sound card for recording??? REDLINEHOOLIGAN Audio 8 May 24, 2007 05:27 PM
