HTPC Build I'd like to have an HTPC, split between the idea of a mediabox or an HTPC. If done, it'll be built from an extra PC I have sitting around. I need it to be able to play blu ray rips at 1080p on the bigscreen. Current specs. Pentium D 3ghz 2GB 533 ram (2x1GB) 250GB Seagate drive (would obviously add a 1.5tb or two) 7600GT (insufficient probably, looking at a cheap ati card with hdmi - Asus 4670 - 52$?) Some intel mobo with 1 pci-e slot and 2 PCI slots DVD RW 300W Sparkle PSU I would need to buy the USB remote for this as well as a video card, basically trying to weigh my options and see what's best. Would upgrading the video card on this PC suffice for a 1080p HTPC? |
With the 4670 I think you'll be just fine. I use a 4670 myself and it's nice. My HTPC uses a E3110 but with that vid card my CPU usage during BD playback is only like 10% so I think your CPU won't limit you. |
CPU may be a bottleneck for v-card |
If you get video and sound non-sync on large HD file (4Gb and up), PC is too slow... |
I know I have a E5200 along with a 8800GT and that plays anything I throw at it. Before the E5200 I had a Celeron 347 OC'd to 4GHz and it could play everything too, well sort of. I had to have nothing running in the background and it would still have the odd issue with some of my more demanding 10+Mbps rips. As for a remote, I ended up purchasing a Pcusa remote. It works great with Windows 7, although I only used the remote portion for about 5 minutes. I now use my Logitech Harmony remote for it. |
Oh yea, I forgot to mention it was all running it through mediaportal. That Celeron did pretty good considering, but the $60ish I paid for the E5200 was worth it for the upgrade. Plus now I can play NFS: Shift on it, so much nicer on the big screen. |
| All times are GMT -7. The time now is 10:17 AM. |
