Old November 2, 2009, 07:14 PM
lcdguy's Avatar
but would a hdmi sound card also pass the dts-hd signal or should i look at something that can do that over digital coax/toslink. Hmm. this is getting expensive i might just have to break down and upgrade my PH.
Old November 2, 2009, 07:52 PM
LionRed's Avatar
You do not/shouldn't have to install codecs for XBMC, they are included in XBMC. SO I am unsure how XBMC will react to a codec package being installed.
XMBC does have some key usage that may seem a little odd. But once you figure it out...it will all be very clear they needed to do it that way. When it seems like it is stuck....give it a few seconds. It hasn't hasn't crashed, just the odd time it seems like it (very rare when this happens actually).
You could use a remote to use on XBMC. I have a FireFly Remote (came with BeyondTV). I hit a button and XBMC starts up....hit another to shut XBMC down.
Choo Choo bitches, progress coming through.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy
Old November 2, 2009, 07:55 PM
lcdguy's Avatar
unfortunately software that get stuck or randomly crashes is an extreme pet peeve for me. so i think i will just be using my htpc as a music player. And live with my popcorn hour until i have the extra cash to upgrade to either the A-110 or C-200. IMHO there are only 2 things missing from the popcorn hour (decent music player and ATSC tuner support)
Old November 2, 2009, 08:15 PM
LionRed's Avatar
How often is it freezing up on you. Cause in 10 months XBMC has crashed maybe twice...done the freeze thing maybe twice a month (every time it does these things, it is something I did...while tweaking or learning what a feature does).
Old November 2, 2009, 08:26 PM
lcdguy's Avatar
while testing playback i have had it become unresponsive at least 2-3 times tonight as well as a program crash. Also the live cd doesn't work properly
Old November 2, 2009, 08:38 PM
LionRed's Avatar
Well...if it was me. I would be doing a format and reinstall of windows. I like to start clean canvas ...cause god knows what installing those codec packages have done =(
I am running XBMC off a e5200, 1GB ram, intel pro 1000GT and a ATI 4550. Runs smooth...plays HD stuff on xbmc with no issues (the movies are played over the network).
I am not as familiar with AMD as I use to be...but it certainly looks like you have more then enough system to run XBMC.
HTPC Help Burkdaddy New Builds 8 July 23, 2009 06:14 AM
HTPC OS? biff HTPC Systems & Software 25 February 26, 2009 06:09 PM
Question about Audio out from Blue Ray HTPC to 24b 192KHz DAC Recevier Babrbarossa Audio 0 November 4, 2008 01:54 PM
Question about parts for HTPC CrazyScott HTPC Systems & Software 8 October 1, 2008 04:07 PM
My HTPC. TopDogZero Case Mods, Worklog & Gallery 1 May 14, 2008 04:53 AM
