Old September 30, 2009, 06:20 PM
Perineum's Avatar
The point of the machine will be to game on it.
I'm saying in my original post that the P5Q-EM won't fold or game, so I want another solution. It would, however, do well at being an HTPC.
Old September 30, 2009, 06:33 PM
Babrbarossa's Avatar
OK- seems like alot pf people misreading the OP- he wants to game on it.
I have tried the SPDIF out on both a 260 and a 285 and they both SUCK for that (often completely garbled)- look for either a motherboard or sound card with a digital audio output- you'll need to run two wires to your amplifier but it's no biggy if your not across the room from it.
Old October 1, 2009, 12:33 AM
Perineum's Avatar
Okay! THAT is what I wanted to know.... seems like onboard (which is only going to do 1 of 3 things I want to do) or ATI discrete (which will at least do 2 of 3, game and movies) is the way to go.
Is there a pass thru connector from SPDIF going to the ATI cards like the GTX260 or does it do it some other way?
Old October 1, 2009, 04:42 AM
bojangles's Avatar
HTPC Systems & Software - Hardware Canucks
Anyway, you could just get a cheap mATX LGA775 ASRock motherboard, a 4870/4890 and an Omega Striker 7.1 or something and voila, you have a perfectly capable gaming HTPC with high quality sound.
I don't know much about them so that's all I could tell you. Good luck!
Old October 1, 2009, 08:34 AM
lowfat's Avatar
You don't need to use one. The ATI cards support full 7.1 LPCM without the use of any connectors.
Mael
Big Lian Li
Forever Alone
Old October 1, 2009, 01:27 PM
Perineum's Avatar
Well that's bloody slick, how does it work? As part of the driver installation does it automatically work or do you have to set your sound to use "ATI digital out"?
Is it possible to use your regular sound output and then use ATI's HDMI LPCM at the same time?
Old October 1, 2009, 04:13 PM
lowfat's Avatar
W/ Windows 7 & Vista you can use more than one sound source. You have to just go in to the sound preferences and set the default before playback, however you can also use this.
Kevin Chiu: Windows Vista Volume Mixer Trick
It should work but I haven't used it in a few years so I don't know for sure.
When you install the newest CAT's they install the sound drivers as well. Then just go in to the Windows Sound preferences, and set the ATI as default, and 7.1. Your receiver should show 7.1 LCMP or multichannel PCM or something along those lines.
Mael
Big Lian Li
Forever Alone
Old October 1, 2009, 05:46 PM
Perineum's Avatar
That's good info, thanks
  #19 (permalink)
Old October 17, 2009, 08:42 PM
I'm not sure if it matters to you, but the hardware in this thread does not support the PAP HDCP crap. If you want to bitstream the new HD codecs (TruHD, DTS HD etc) to a receiver, you'll need the 5xxx series of Radeon.
  #20 (permalink)
Old October 17, 2009, 10:44 PM
Perineum's Avatar
Oh, it definately matters to me, thanks for the info, I appreciate it.
Off topic watercolling: Any webdesign gurus here? Dazmode Water Cooling 19 November 30, 2009 04:43 PM
HTPC Help Burkdaddy New Builds 8 July 23, 2009 06:14 AM
Need some advice from Network Gurus Prof. Dr. Silver Networking 23 July 11, 2009 01:18 AM
Need gamepad help from Linux gurus, please! vulcan500rider O/S's, Drivers & General Software 3 June 3, 2009 07:52 AM
