  #41 (permalink)
Old December 26, 2009, 06:22 PM
lowfat's Avatar
AFAIK nope. I don't suppse you have a different computer to try merging them on?
  #42 (permalink)
Old December 26, 2009, 07:14 PM
biff's Avatar
Just working on trying that now. Trying to get the other computer to see the new drive I just put in... been at it for an hour now. F***ing M$! networking used to be soooo easy!
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
  #43 (permalink)
Old December 26, 2009, 10:15 PM
biff's Avatar
Merging worked the first attempt but same error on other attempts... frustrating!
Asus P5Q-PRO
EVGA GTX 280 (SC?)
  #44 (permalink)
Old December 26, 2009, 10:17 PM
lowfat's Avatar
I really have no idea. You are using the newest versions of madflac, mkvmerge, and eac3to?
  #45 (permalink)
Old December 26, 2009, 11:16 PM
biff's Avatar
Yep.... maybe something of interest is that the second computer has no flac codecs at all yet merged the files fine (again only the first time).
BTW, I'm trying to poo-poo on your tutorial incase you're getting that impression, I certainly appreciate your effort. Obviously my issues seem to be 'unique' I'm assuming since google isn't turning up anything - yet. I guess I'll just have to keep digging and trying different things. Do you think maybe it would have something to do with copy protection? I wouldn't think so since anydvd already got it onto the drive, but I'm pretty green at this. Second, while running eac3to it reported a couple errors of sorts, mostly reporting it couldn't use the entire 64bit depth and it reported clipping so had to do a second run. Not sure if that's normal or has anything to do with this.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
  #46 (permalink)
Old December 26, 2009, 11:46 PM
lowfat's Avatar
The part about not having a 24-bit depth is normal. A lot of movies don't take advantage of 24-bit sound. Only 16 bits actually carry useful sound. So eac3to reduces it to 16-bit to save on space.
Don't think that is a copy protection thing. If that were the case eac3to wouldn't have been able to rip it in the first place.
If you had a way to uploading a tiny mkv & flac file somewhere I can see what it does on my machine. That way you would know if it was an eac3to issue or mkvmerge. Maybe rip a trailer or something from a bluray.
  #47 (permalink)
Old May 7, 2010, 09:15 PM
lowfat's Avatar
Edited the playback section to remove ffdshow. Add AC3filter instead. And added details on how to use MPC-HC instead.
  #48 (permalink)
Old May 7, 2010, 09:47 PM
interesting. if you mess up your precious discs you still have a copy of them.
also, do you actually need an oc'ed i7 to do the job timely or...? :)
  #49 (permalink)
Old May 7, 2010, 10:15 PM
lowfat's Avatar
Or in my case, if they get stolen.
You only need a fast processor if you are encoding them. If you want perfect lossless copies you could do it on a Pentium 4 really all you are doing is separating the audio and video tracks then throwing them in to a different container.
But if you are encoding them to get them slightly smaller a fast processor is definitely handy. An E8400 would likely take a week to encode a single movie.
  #50 (permalink)
Old May 7, 2010, 10:19 PM
With the cost of the blanks, and the massive amount of time involved, I just store them on hard drives. Though I do have a bunch of drives.
XBMC in all its beauty. lowfat HTPC Systems & Software 27 September 18, 2009 05:22 PM
Some blurays are choppy... biff HTPC Systems & Software 8 September 5, 2009 08:03 PM
Looking for software recomendations for DVD ripping Cowinacape O/S's, Drivers & General Software 4 November 24, 2008 09:14 PM
Best DVD Burning/Ripping Software? bojangles O/S's, Drivers & General Software 3 October 11, 2008 10:43 AM
HTPC Software/Codecs Thunderbirt HTPC Systems & Software 10 January 24, 2008 05:35 PM
