  #31 (permalink)
Old December 17, 2009, 03:52 PM
PLg PLg is offline
well maybe that's the problem. I am a good student and I was told to only use flac as it was the best quality out there.
  #32 (permalink)
Old December 18, 2009, 10:54 PM
biff's Avatar
It works!! but only so-so. I'm noticing the video is a little glitchy but not too bad, but the audio is gets really choppy at times. I don't have the slightest as to where to even start to track down the issues. I do notice that the HDD light is lit up almost constantly and CPU usage is usually from 50% to 80% during play back. Maybe I'm hardware limited?
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
  #33 (permalink)
Old December 19, 2009, 12:12 AM
lowfat's Avatar
What are you using for playback? It does take a rather powerful CPU for playback. Playback on my Q8200 @ 3.2GHz averages about 15-20% CPU usage while playing a movie.
You can try MPC-HC w/ this guide for DXVA. Watching h.264 videos using DirectX Video Acceleration (DXVA). | My collection of short anime reviews
I don't know if it will work movies encoded w/ VC-1 though. AFAIK it will only help w/ MPEG-4 (h.264).
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #34 (permalink)
Old December 19, 2009, 12:39 AM
biff's Avatar
I tried WMP and I think a couple others. My htpc has a e3110 (e8400 equiv.) at the stock 3.0GHz 2bg Ram and a ATI 4670HD.
I'm still up in the air about frontends but I'm slowly going over to XBMC. I really like VMC's polished look... my wife (or friends) can just pick up the remote and use it which is a huge plus but XBMC seems much more customizable but looks like it's going to take a lot of work on my end to make it as slick as VMC, though at the same time make it better than VMC. At least it has tools to work with.
Anyway I'd like to hear how to get classic media player into XBMC. I tried googling and kept coming across XML (IIRC) code and that's beyond me at this point. Even if I could cut & paste I wouldn't know what to do with it.
Edit: BTW I think the movie I used was VC-1
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
  #35 (permalink)
Old December 19, 2009, 01:01 AM
lowfat's Avatar
Ya XBMC does take a lot of work to look/play nice. I can't remember how to get an external player (MPC) to work w/ XBMC at the moment. As my TV was stolen a while back I haven't used my HTPC in a while. Once I get up and running again, I'll let you know how to setup MPC w/ it.
Queen of Dreams WIP
Big Lian Li
Complete
  #36 (permalink)
Old December 20, 2009, 09:08 PM
biff's Avatar
Tried a second movie and having some issues. Using mkvmerge I get this error while pre-parsing the flac "Error: flac_reader: Error parsing the file: 3". Seen it before? Any ideas?
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
  #37 (permalink)
Old December 20, 2009, 09:38 PM
lowfat's Avatar
No I haven't. Have you tried a different movie to see if it happens again?
Queen of Dreams WIP
Big Lian Li
Complete
  #38 (permalink)
Old December 26, 2009, 04:51 PM
biff's Avatar
FWIW I tried using WAV and had no problems... no idea why that is. Also playback seems to be fine now. Might have something to do with BOINC I think so I've adjusted those settings. BTW Any harm in using WAV over flac for audio besides a few wasted MB's? AFAIK there is no difference SQ wise. I use flac for all my audio files (as in music) because I can attach ID tags for track info but I can't see that being a necessity here.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
  #39 (permalink)
Old December 26, 2009, 04:57 PM
lowfat's Avatar
WAV's are going to considerably larger in size and AFAIK nothing will play it w/ 24-bit depth. AFAIK using Flac w/ madFlac is the only way this is possible.
Queen of Dreams WIP
Big Lian Li
Complete
  #40 (permalink)
Old December 26, 2009, 07:17 PM
biff's Avatar
Tried a couple other movies and mkvmerge still failing diring the 'parsing the flac' bit. The flac works, I can play it in WMP no problem. Tried uninstalling/reinstalling mkvmerge as well as different versions and no joy. Anything else that can merge the audio and video?
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
XBMC in all its beauty. lowfat HTPC Systems & Software 27 September 18, 2009 05:22 PM
Some blurays are choppy... biff HTPC Systems & Software 8 September 5, 2009 08:03 PM
Looking for software recomendations for DVD ripping Cowinacape O/S's, Drivers & General Software 4 November 24, 2008 10:14 PM
Best DVD Burning/Ripping Software? bojangles O/S's, Drivers & General Software 3 October 11, 2008 10:43 AM
HTPC Software/Codecs Thunderbirt HTPC Systems & Software 10 January 24, 2008 06:35 PM
