Old September 17, 2009, 06:58 PM
Shadowmeph's Avatar
Default How do I take TV audio and plugit into my PC
I have been using mediaportal and well ,it has been working pretty good but I just want to use part of media portal ( accessing video files) and use my TV for TV . but I want my audio coming from my TV which has rca output jacks and plug them into my PC so I can use the head phones from my PC for sound while watching tv, I can do this right now but I down liike the dellays when changing channels in media portal but I like the sound quality of my Xonar dx card so how do I do this. do I get an adapter that converts the rca audio out to the Xonar card ( haven't looked at it quite yet) ? and when I am watching tv will I be able to hear the output of my TV or would I have to change something in the audio config?
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old September 18, 2009, 02:20 AM
MacJunky's Avatar
You want something like this:
NCIX.com - Buy nGear 2RCA to 3.5MM Stereo Audio Cable 2M/M 1.5M 5FT - QC-304 In Canada..
You can most likely find another one cheaper.. but whatever.
Just plug one end into your TV's output and the other into your soundcard's line level input.(line_in)
This is assuming that I am understanding what you want.. And to be fair I am not sure if I am.
Old September 18, 2009, 09:23 AM
Shadowmeph's Avatar
thats what I thought Thanks
Folder :
AC'97 and HD AUDIO p3dro Troubleshooting 4 February 25, 2009 09:02 AM
Help with tv to pc audio overlords Audio 13 July 14, 2008 09:15 PM
Audio Options? Lyxtwing Mobile Computing 2 May 25, 2008 11:20 PM
audio on the cheap zaqu Audio 6 June 28, 2007 05:29 PM
no audio mo' power Audio 8 February 9, 2007 08:07 PM
