Old September 8, 2009, 05:31 PM
lowfat's Avatar
Its a Media Front end. Like Windows Media Center. Add your movies, tv shows, etc. And as long as you set up the scrapers properly it will grab all the fanart, dvd covers, synopsis', etc.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old September 8, 2009, 05:44 PM
WolfBane's Avatar
very nice i am playing with it now but i see have a bit of learning to do befoe i get the full jist of it:)
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
Old September 16, 2009, 01:26 PM
check out the aeon hitched skin. best looking skin imo. haven't figured out how to get it to work yet as i get errors with the new build of xbmc with win7
Old September 16, 2009, 04:35 PM
lowfat's Avatar
Every variation of Aeon I used i did not like. The cut down on the user interface to make things prettier.
Queen of Dreams WIP
Big Lian Li
Complete
Old September 16, 2009, 05:17 PM
artistpavel's Avatar
I spent days trying to figure out how to setup scrapers, but my movies still appear as filenames in folders, not a single piece of background art. :help:
х58forLife
Old September 16, 2009, 05:27 PM
lowfat's Avatar
So you go in to videos. Click add source, select your movie folder. At the bottom select set content. Next screen is where you pick the scraper. I suggest going w/ IMDB but allow TMDB. If you did all this and you still can't view backgrounds images, etc you are in 'library mode' The stock skin AFAIK can only do library mode. You can use MediaStream which is bundled w/ XMBC. That way you can go to 'Movies' on the home screen. Here you should see your movies correctly.
Queen of Dreams WIP
Big Lian Li
Complete
Old September 16, 2009, 06:17 PM
LionRed's Avatar
Scrappers are already in XBMC. No need to go find them to install. Took me a couple times trying XBMC to figure it out myself.
Once I found em I was like sob, they are in here.
Not sure where he is going wrong lowfat. But mine was in mapping the folders. Then forgetting to set content.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Old September 16, 2009, 11:07 PM
Yes, set content was the key, thanks.
х58forLife
  #19 (permalink)
Old September 17, 2009, 05:09 PM
mattlef's Avatar
This is a fantastic looking xbmc skin.
makes me want to go out and build a htpc now lol
CC-HotSpot Host
YouTube Instagram Twitter
  #20 (permalink)
Old September 17, 2009, 06:02 PM
Now I'm looking for a good irremote.ini presets for my Hauppauge 45-button remote.
х58forLife
