Old August 25, 2009, 03:47 PM
Varroa's Avatar
Default HTPC case
Hi Guys, I recently purchased a Nmedia 1000B. It is a great case and I would love to use it but it is too deep for the bookshelf that I need to place it on. Does anybody know of a HTPC case that is not so deep? I don't mind if it is taller but I need something about 4 inches shorter at least. Any ideas? Thanks
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old August 25, 2009, 04:20 PM
Micro ATX Computer Cases, Micro Computer Case, Micro Tower Case TigerDirect.ca
look here to find the one you want. then google to find a lower price :D
Old August 25, 2009, 04:54 PM
Varroa's Avatar
"Weapons over here!"
Thank you Mr. Obvious! If I had found one when I looked on my own I wouldn't have bothered asking. Since I already looked and couldn't find one 12 inches deep I decided to ask the forum for help, hoping somebody specifically knew of one.
Anybody else?
Old August 25, 2009, 05:28 PM
SugarJ's Avatar
I think you'll have tough luck finding one that much shallower in depth. The mATX standard depth is 9.6". To have a 12" deep case you'd have to hang the drives way over the mobo, probably interfering with the HSF.
I'm going hunting for you though, will report back. It might be easier to replace the bookcase.
Old August 25, 2009, 05:36 PM
SugarJ's Avatar
What about a SFF case, instead of an HTPC case? Look at this Lian Li - Lian Li (PC-Q07B, PC-Q07-B) Aluminum Mini Tower Computer PC Case- Mini ITX Chassis, BLACK
Edit: NVM, it is a mITX case, not mATX.
Double Edit: Aerocool, under 14" deep, NCIX.com - Buy AeroCool M-40 Black mATX Cube Case 2X5.25 1X3.5 2X3.5INT No PS LCD Display Front USB & Sound - M40-BK In Canada.
Old August 25, 2009, 06:20 PM
Varroa's Avatar
I did a bunch of measuring and draft install on my Nmedia case and i think I can cut it down to 12inches and still fit everything in (with the HDD cages overtop of the mobo). I am still hoping for a off the self option but if that fails then I will be cutting up my brand new case. The book shelf is the only option in the space so I can't change that.
Thanks for the help and let me know if you find anything. I sure couldn't!
[WTB] Looking for HTPC case Varroa Buy/Sell & Trade 5 August 15, 2009 05:43 AM
[WTB] HTPC case dadzilla Buy/Sell & Trade 4 January 25, 2009 08:32 AM
Looking for HTPC case and HSF Cypher^64 HTPC Systems & Software 7 November 10, 2008 08:39 PM
HSF for a Quad Core in HTPC case BALISTX Air Cooling 2 August 25, 2008 05:42 PM
