-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   Netbook as remote? (http://www.hardwarecanucks.com/forum/htpc-systems-software/22288-netbook-remote.html)
Cypher^64 August 25, 2009 12:05 PM
Netbook as remote?
I was given an acer netbook from work and was wondering if there would be any way to make this into my remote for my Windows 7 HTPC with media center?
cdn_Madrach August 25, 2009 01:20 PM
The only thing I can think of is using remote desktop or vnc.
JD August 25, 2009 01:23 PM
Not like it has an IR port on it or anything. Even if it did, you'd probably have some weird angle to hold it at to make it work.
cdn_Madrach August 25, 2009 01:31 PM
If you do decide to use either vnc or remote desk top consider that there will some lag involved. Not like using an ir controller.
Cypher^64 August 25, 2009 02:45 PM
Actually, I just found some decent software for my old HTC Touch that's been sitting in a drawer that should work good via bluetooth. Now if I could just get it to control my tv as well.... hmm...
Guess I'll have to find another use for the net book.
rashid204 August 25, 2009 04:23 PM
how about folding ;)
MacJunky August 25, 2009 04:37 PM
Folding on a netbook is not even funny.
shame on you.
