Old August 13, 2009, 09:44 PM
Shadowmeph's Avatar
Default how do I get the tv guide in MP to work?
I cannot figure that out it would be a real bonus if I could use the guide but for some reason it doen't have any Canadian sites on other countries. I had thought that there was a way to access the Zap2it tv guide or am I getting mixed up with mythbuntu?
or is it one of those pay for things
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old August 17, 2009, 02:08 PM
Shadowmeph's Avatar
hmm I am thinking that since we are Canadian we get know free guides up here
Folder :
Old August 17, 2009, 08:27 PM
artistpavel's Avatar
I'll be installing one of those media center software soon and would like to know everything about it too, including tv guide.
Old August 17, 2009, 10:57 PM
JD JD is offline
All I can suggest is posting/searching the MediaPortal forums. I don't use TV through my HTPC so I have no idea.
Old August 20, 2009, 02:05 PM
Shadowmeph's Avatar
I am not sure about that web site because I have posted a couple of things asking for help and never received any replies. At first I thought that maybe my questions had an obvious answer to them, but then I would expect some type of reply, even if it was a negative response but I haven't' received any responses at all. I cry discrimination that are all prejudice against Canadians
Folder :
Old August 20, 2009, 08:36 PM
JD JD is offline
Well I wouldn't say it's the most active forum either, but you should of got some reply of some sort...
Old August 21, 2009, 07:25 AM
Lowfat mentioned in other thread he uses BeyondTV, I assume with TV guide, so Canadian TV listings must exist somewhere.
Old August 21, 2009, 07:38 AM
LionRed's Avatar
I'd suggest spending some money on SageTV or BeyondTV, for watching TV. They both have free trials. BTV is my preference. Best of all BTV, SageTV are fairly wife proof...and wife approved. But if you are not married...then knock yourself out with MP.
If you want some eye candy..then use XBMC(free) with BTV or SageTV. XBMC is very user friendly.
Choo Choo bitches, progress coming through.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy
HDTV PC Tuner Guide Lima HTPC Systems & Software 14 October 28, 2009 01:03 PM
WaterCooling Component Guide freakgeek1337 Water Cooling 47 October 16, 2009 11:04 AM
My guide to a smooth running PC Toronto122 O/S's, Drivers & General Software 27 April 14, 2009 03:00 PM
Graphics Card Guide Cranky Video Cards 1 December 8, 2008 07:06 AM
Watercooling Guide Sticky BALISTX Water Cooling 1 October 10, 2007 10:00 PM
