  #21 (permalink)
Old August 13, 2009, 03:25 PM
JD JD is offline
Not sure since it's a "special" jack as you can clearly see the red light emitting from it. No idea if it has the proper electrical contacts inside for an adapter like that to work.
  #22 (permalink)
Old August 13, 2009, 04:08 PM
TopDogZero's Avatar
Originally Posted by artistpavel View Post
No I'm trying to connect digital SPDIF from Xonar to my 5.1 amplifier that has digital Coax In, and standard coaxial audio cable doesn't match Xonar's 3.5mm jack, so I was looking for adapter of some sort.
Basically I want to plug this into Xonar SPDIF out:
Ah got ya, I think it won't work like jdrom17 said it's a special jack. I believe analog when used like a regular jack and digital when the Toslink adapteris inserted? You'll probably have to use the Toslink adapter and the S/PDIF to Coax converter you have.
  #23 (permalink)
Old August 14, 2009, 04:21 PM
artistpavel's Avatar
Originally Posted by Sushi Warrior View Post
May as well of got a 9600GSO for same price after rebate. Also may be able to trick the PM into accepting a price from another site after MIR then it would be $20 after MIR.
Hey, I checked, the 8400GS I picked is 65nm G98 with VC-1 video decoding, and that 9600GSO is the older G92. Good catch though, 9600GSO is essentially 8800GS in power department.
х58forLife
  #24 (permalink)
Old August 14, 2009, 05:59 PM
Sushi Warrior's Avatar
Really? 8400 is G98? That's neat.
  #25 (permalink)
Old August 14, 2009, 06:03 PM
It used to be G86 and they re-released it as G98 under the same name.
At the end of 2007, NVIDIA released a new Geforce 8400 GS based on the G98 (D8M) chip.[8] It is quite different from the G86 used for the "first" 8400 GS, as the G98 features VC-1 video decoding completely in hardware, lower power consumption, lowered 3D-performance and a smaller fabrication process. The G98 also features dual-link DVI support and PCI Express 2.0. G86 and G98 cards are both sold as "8400 GS", the difference can only be told from technical specifications.
х58forLife
  #26 (permalink)
Old August 15, 2009, 07:42 AM
Nodscene's Avatar
Artistpavel, I have an Antec Fusion Remote Max that I'm looking to get rid of. It has seen very light use and is in perfect condition. If you are interested let me know. Canada Computers - Cases > Desktop/Cube : Antec Fusion Remote MAX Media ATX Desktop Case.
Thanks
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
  #27 (permalink)
Old August 15, 2009, 01:48 PM
I got the case ordered, but thanks for offer.
х58forLife
Have spare machine, will build HTPC... Caldezar HTPC Systems & Software 10 January 27, 2009 02:27 PM
The Spare Parts PC! Chilly Case Mods, Worklog & Gallery 12 December 5, 2008 10:32 AM
$500 Parts Budget BALISTX New Builds 15 October 26, 2008 06:19 AM
FS: Bo's Spare PC Parts! bojangles Buy/Sell & Trade 20 October 10, 2008 05:26 AM
Budget HTPC BALISTX HTPC Systems & Software 4 May 28, 2007 08:16 AM
