<~----> Quality issue using dvi to hdmi? - Hardware Canucks
Old August 5, 2009, 08:39 AM
odis172's Avatar
Default Quality issue using dvi to hdmi?
Im trying to find a solution for a friend, that wants to run 2 lcds, and a 1080p (hdmi) tv from his computer. I was thinking about using a triple head2go, to route the 1 dvi to the 2 screens, then using a dvi to hdmi converter to go to the tv. I figure this should work, but my friend is concerned that the tv will look bad, cause its not an hdmi port. Any thoughts, or suggestions on an alternate solution.
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old August 5, 2009, 08:48 AM
CMetaphor's Avatar
Quadfather
DVI is equal to HDMI in terms of bandwidth, so running his TV using a DVI to HDMI cable @ 1080p should be no problem and show no difference in quality. The only real difference is that HDMI also carries audio, DVI does not.
For his other two monitors, why do you need a Triplehead2go when he only has two? A Dualhead2go, just like the triplehead, can go up to 2x 1900x1200 without a problem.
Old August 5, 2009, 10:11 AM
odis172's Avatar
Ah dual head2go, didnt know it existed! Does the product allow you to use 2 independant monitors in windows, just as if they had both had a dedicated dvi port?
Old August 5, 2009, 10:14 AM
CMetaphor's Avatar
Quadfather
No. Both the dualhead2go and triplehead2go appear as a single super-wide monitor in windows. Games will be stretched across both monitors if theyre both on and using the super-wide resolution. However, you can still have them act as independant monitors by using 1) a desktop divider and 2) using a single monitor in-game resolution if necessary.
Old August 5, 2009, 04:48 PM
grinder's Avatar
yup... what Cmetaphor said. The tripplehead or dual head makes a virtual superwide monitor. So when you fullscreen it's cut off on the display.
i.e.
a dualhead2go hooked up to two 1024x768 monitors will show up as a single 2048x768 monitor in the operating system.
The setup you speak of it typical of a video editing computer. Dual monitors for mixing video and audio and a third display ported directly to a TV or HD monitor for real-time proofing. Perhaps the best way to go about this is two video cards NOT in SLI. One video card with dual DVI for LCD monitors and another video card dedicated to HDMI out for your HDTV.
DVI-I vs HDMI what shoud I use.... Gameplaywarrior Display Units 5 November 13, 2008 04:55 PM
HDMI Audio Issue lcdguy HTPC Systems & Software 15 November 12, 2008 09:52 PM
LF DVI-I to HDMI Adapter earlgrey Buy/Sell & Trade 10 September 7, 2008 02:12 PM
Video card dead? DVI cable issue? Matty D Troubleshooting 10 March 15, 2008 12:54 PM
Dvi to Hdmi adapter? cdn_Madrach HTPC Systems & Software 12 October 24, 2007 10:46 AM
