Old August 5, 2009, 06:34 AM
Default What USB dongle to use with Popcorn Hour A-110
Hi everyone,
I had no answer asking this in the networking forum, so I ask my question again in this forum. I would like to know wich usb wifi dongle will works with the popcorn hour a-110.
It is not for streaming but for the storage and BT part of the machine. I plan to put my WD Black 1TB drive inside the PH.
THanks all
E8400 | Xigmatek HDT-S1283 | GA-EP45-DS3L | OCZ XTC Platinum Edition PC2-8500 4X2GB | HD 4890 1GB | Corsair Tx750W | Samsung 245BW | WD 1TB Caviar Black | Turtle Beach Ear Force X-52 | Antec Three Hundred
Old August 5, 2009, 07:44 AM
bojangles's Avatar
You will run into numerous problems when using a USB WiFi dongle. Connectivity issues will happen. Is there a way getting a wired connection to it?
Networked Media Tank
Old August 5, 2009, 07:55 AM
sure, having a wire from my router (in the living room) to the PH (in the master bedroom). The wife won't be happy :P
Old August 5, 2009, 08:30 AM
lcdguy's Avatar
a co worker of mine tried the wireless dongle from popcorn hour. It did not work to well. Since it's 802.11n only. If it were me i would stick with wired. It's not worth the extra cost and headaches compared to a run a rj45 cabling.
Old August 5, 2009, 08:41 AM
I'll try something, but thanks for the idea.
If i run the cable, am I better with streaming or with putting the hdd inside the PH?
Old August 5, 2009, 10:25 AM
lcdguy's Avatar
i personally opted to stream to mine but that's just me. This is how i have mine setup.
Computer -> popcorn hour (mounted smb share)
Old August 5, 2009, 07:10 PM
Ill probably install my WD Black 1TB inside the popcorn hour so it will take care of my torrents and will act as a NAS.
Just need to decide wich HDD will go in my main rig now...
Old August 7, 2009, 11:33 PM
coriolis's Avatar
You want a TL-WN821N USB stick, I believe. My local store has them for $26 but they are OOS until Monday, I'll stop by then and grab one.
Old August 9, 2009, 03:56 PM
what local store? NCIX?
Old August 9, 2009, 06:16 PM
coriolis's Avatar
CTY.ca, its in Richmond Hill, Ontario. I called them yesterday as the guy there told me to to double check and he said they might not get any until later this month, something about a distribution problem in the States.
Anyways, I found it for $23 at NewEgg, pricematched it at NCIX, should be here within early this week, I hope.
Newegg.ca - TP-LINK TL-WN821N IEEE 802.11b/g, IEEE 802.11n Draft 2.0 USB 2.0 Wireless N Adapter Up to 300Mbps Data Rates 64/128/152 bit WEP, WPA/WPA2, WPA-PSK/WPA2-PSK (TKIP/AES) - Wireless Adapters
I'll try it out and post back here, but I've been told it should work.
What USB dongle to use with Popcorn Hour A-110 Bomberman07 Networking 0 August 4, 2009 03:03 PM
[FS] Microsoft Reclusa and Habu, Logitech EX 110 ricknash61 Buy/Sell & Trade 3 July 19, 2009 07:56 PM
Help me build a HTPC before I buy the popcorn hour elec999 HTPC Systems & Software 12 May 15, 2009 08:55 AM
Earth Hour geokilla Off Topic 58 March 31, 2009 09:36 AM
ION iTTUSB 10 USB Turntable Reviewed @ Everything USB Supergrover Reviews & Articles from the Web 4 August 29, 2007 05:11 PM
