Old July 31, 2009, 03:49 PM
3 of 7's Avatar
Default My Airflow Mod for Passive R4350
The case is a Rosewill matx .
Newegg.ca - Rosewill R115-P BK Black SECC Steel MicroATX Mid Tower Computer Case - Computer Cases
Inside is a P4 3.0c Northwood in an MSI 945GCM478,
Newegg.ca - MSI 945GCM478-L 478 Intel 945GC Micro ATX Intel Motherboard - Intel Motherboards
2g of DDR2 and a 350W Sparkle 120mm PSU
I cut the receiver for a Mediagate Windows Vista MCE Infrared Remote Control into the floppy slot cover with my trusty dremmel.
NCIX.com - Buy Mediagate Windows Vista MCE Infrared Remote Control for Home Premium & Ultimate Black - GP-IR01BK In Canada.
I previosly had anXT1650 that died when I tried running the fan at 5V so I got an MSI R4350 Passive.
I haven't been able to get ATITOOLS to read the temps on it.
I took a cpu airhorn off an old case and bolted it to my sidecover with a blockoff plate and aimed it directly at the gpu.
Nature always sides with the hidden flaw
Old July 31, 2009, 03:50 PM
3 of 7's Avatar
As you can see in this pic (sort of) the horn is aimed pretty good.
Old July 31, 2009, 03:51 PM
3 of 7's Avatar
I risked life and limb and snuck a smoke into my office to see if it works and it seems like it is.
Old July 31, 2009, 03:52 PM
3 of 7's Avatar
Anyone know of a program that will read the temps on this card?
Old July 31, 2009, 03:53 PM
yamawho's Avatar
Interesting one Robert
Old July 31, 2009, 03:54 PM
gingerbee's Avatar
gpuz does not work?
Old July 31, 2009, 03:58 PM
3 of 7's Avatar
Originally Posted by gingerbee View Post
gpuz does not work?
hang on I'll give it a go
3 of 7's Avatar
Thanx Eric
Old July 31, 2009, 04:04 PM
Arinoth's Avatar
I was just going to ask what temps you get, i found HWMonitor works at least with my parent's Pentium D: http://www.cpuid.com/download/hwmoni..._114_setup.exe
Old July 31, 2009, 04:08 PM
3 of 7's Avatar
GPUZ works fine thnks.
Here's the idle temps (Ambient is 28c)
I'll let it run for a while with media center running a movie and see how it goes.
UV Mod = Epic mod, makes ur computer look 100x Better arekieh Case Mods, Worklog & Gallery 12 March 29, 2009 12:13 PM
my cm690 airflow? CTA Air Cooling 15 September 6, 2008 12:35 AM
Antec Plusview 1000 Mod, my first mod need help... thatguy Cases 6 July 14, 2008 08:48 PM
New case airflow tubabub New Builds 11 July 2, 2008 08:28 PM
Check your airflow sir????? sswilson Troubleshooting 8 February 25, 2007 09:29 AM
