Old July 24, 2009, 11:17 AM
Shadowmeph's Avatar
Default HTPC Build suggestions
ok I am totally new to the HTPC but I will give you a list of what I have so far and would like some suggestions\ ideas and any other constructive criticism.
Part I have so far;
CPU= AMD athlon 64x2 3800,
Mother board= MSI K9N6PGM2-V AM2 GF6100 RT
TV card= HVR -1600 ( have remote and ir thing,
Ram= 4x1gb sticks DDR2- 800 ( not sure if I would need them all )
case = something laying around or any suggestions
for Video card I have two choices; Asus 7900 GT or a HIS IceQ3 HD 3870
I also have a Xonar DX sound card but I am not sure if it still works.
that is all the parts that I have for now I also not sure which Operating system and other software to use.
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old July 24, 2009, 01:19 PM
JD JD is offline
Seems like it would be a fine setup, use the HD3870 since then you have HDMI w/ audio if needed. Also better video quality than NVIDIA IMO.
Don't really need a sound card assuming your onboard has digital out and your have a surround sound setup.
Old July 24, 2009, 10:10 PM
First off I would like to second choosing the ATI video card, better cooling solution and more complete HD offloading compared to the nvidia card. In regards to selecting a case, it depends on where you plan to put this htpc, and whether or not you care how it looks along side your other equipment. Personally, my htpc's are in an antec p150 and a antec slk3800b sitting beside my TV stands. If your looking for something on the cheap, the Nmedia HTPC-6000B looks damn nice for the price.
Also if you could provide a little more info about what you plan to use the HTPC for would be a huge help, ie TV recording/playback, digital movie collection storage, etc.
Old July 24, 2009, 11:13 PM
Chilly's Avatar
ATi is awreasome yes, but if you want a decent HTPC just get a zoTAC 9400 based atom motherbiaord, whil with GPU acceleration will prodvide sall the power you need, a whole syetnm will cosxt you under 300$, seripiujsluy man!
Newegg.ca - ZOTAC IONITX-B-E Intel Atom N230 1.6GHz NVIDIA ION Mini ITX ION Platform Motherboard/CPU Combo - Motherboard / CPU / VGA Combo
Plus LINUX nand and XMBC witch support sVIDAPOW and HPU accleratiopn will give you all the power you need. Asdddd 2GB or 4GB or ram, a nice case, a decentr
PSU and a DVD/Blu-Ray drive and BOOM you got a nice HTPCV
"Let's face it, we're not changing the world. We're building a product that helps people buy more crap - and watch porn."
Bill Watkins, CEO Seagate Technology
Dual Xeon X5650 @ 4.1GHz | EVGA Classified SR-2
2x4GB G.Skill at 1496MHz (9-9-9-24) | XFX 4890 XXX 1GB at 1000/1000MHz
Intel SSD X25-M 80GB Gen2 | Western Digital 1TB Black | SilverStone Zeus 1200W
Sound Blaster X-Fi XtremeMusic | Sony MDR-V700 | Windows Seven x64
Stuff for Sale! You must buy it, you can't look away!
Tags
htpc suggestions
Need suggestions on new PC build markmilo1115 New Builds 7 July 14, 2009 10:03 PM
HTPC + Media Server; Suggestions? Wall86 HTPC Systems & Software 3 May 21, 2009 06:42 PM
HTPC freeware suggestions Mr. Gruntsworthy O/S's, Drivers & General Software 7 May 7, 2009 10:54 AM
New build suggestions. taal CPU's and Motherboards 1 February 4, 2008 10:58 PM
Suggestions on WC build sswilson Water Cooling 18 September 19, 2007 03:05 PM
