<~----> wondering which OS to use for HTPC build - Page 3 - Hardware Canucks
  #21 (permalink)
Old August 14, 2009, 11:51 PM
lowfat's Avatar
Originally Posted by artistpavel View Post
Has anyone tried using Windows 7 RC for HTPC, with XBMC? 32-bit or 64?
I am using it now. New mobo didn't want to boot on the old Vista install Works great so far. Although I am not using the RC I am using build 7600. I don't see it being a problem though.
At first I tried MediaPortal and the 'grabber' for TV show pissed me off beyond belief. So went back to XBMC.
  #22 (permalink)
Old August 15, 2009, 12:56 AM
artistpavel's Avatar
That's good news. Is it possible to get TV shows streaming without US locale restriction? Do TV tuners require plugins to work with XBMC?
  #23 (permalink)
Old August 15, 2009, 10:19 AM
Shadowmeph's Avatar
I am not sure what you mean by US local restriction?
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
  #24 (permalink)
Old August 15, 2009, 10:41 AM
grinder's Avatar
i think he's talking about sites like hulu.com, where you try to watch a streaming TV show but get "denied" because you are not located in the united states.
  #25 (permalink)
Old August 15, 2009, 11:02 AM
Yes, exactly, I'm not really familiar with how XBMC works.
  #26 (permalink)
Old August 15, 2009, 11:46 AM
lowfat's Avatar
XBMC isn't for recording. AFAIK it isn't possible with it. I do all my Recording with BeyondTV (not free though). I cut the commercials and convert them to MKV then throw them in the XBMC library.
  #27 (permalink)
Old August 16, 2009, 04:57 AM
Wurmer's Avatar
I have been using Vista home premium, for my HTPC and found it worked decently well but I can't really compare since I have not tried other software. For cutting commercial I am using a little free program called lifextender, it's not perfect and won't work 100 % of the time, some show will not be processed but for the most part it does exactly what it says it does.
  #28 (permalink)
Old August 17, 2009, 10:26 AM
XBMC is poking the idea of brining PVR functionality with MediaPortal plugin or something like that:
Unified PVR front-end (DVR/HTPC client GUI with EPG) and Addons API for PVR back-ends - XBMC Community Forum
Possible HTPC build lcdguy HTPC Systems & Software 29 November 18, 2008 10:42 AM
Yet another HTPC build- help? misterd HTPC Systems & Software 4 August 1, 2008 10:10 AM
Wondering about my Next Build Dashock Off Topic 6 July 19, 2008 01:50 PM
HTPC Build Phobia HTPC Systems & Software 15 July 16, 2008 10:07 AM
Looking to build a HTPC? Babrbarossa Press Releases & Tech News 0 February 16, 2007 10:51 AM
