Old July 6, 2009, 12:33 PM
Cranky's Avatar
Default OTA DVR?
Hey guys, I'm looking for a DVR to hook up to my antenna, any reputable dealers in Canada? and if so, what are some good make and models? Also, is there anything I can add to my computer to make it a OTA DVR?
Thanks
Asus P5K Deluxe / Intel Core2Quad Q9550@8x425@3400mhz(1.225v) / Arctic Cooling Freezer 7 Pro / 4Gigs DDR2 1066mhz(5-5-5-15) Corsair Dominator / Diamond HD4870x2 / Asus Xonar / WD Raptor 74gb / Hitachi 160GB / Antec Quattro 850w / Logitech Z-680 5.1 / Dell Ultrasharp 24" / 2 LG Optical Drives / Vista Ultimate 32bit / A tower that's been drilled, cut, and bent to fit all of my fans
Old July 6, 2009, 12:37 PM
lcdguy's Avatar
unfortunately in canada OTA isn't what it is in the US. The only ones i have found are the samsung boxes and they are pretty pricey. Your best bet would be to get a ATSC tuner card and build a cheap HTPC since it will cost around the same but is more useful.
Old July 6, 2009, 01:54 PM
you can look into getting a Dvico pci card for receiving OTA HD channels - I've tried it and it works well, but depending on where you are will impact how many channels you can get
Desktop: Asus Maximus V Gene | 3570K @ 4.2Ghz | 4x4GB G.Skill DDR3-1600 16GBXL 9-9-9-24 | Patriot PYRO SE 240GB SSD | Zotac nVidia 560ti | Seasonic X-460FL 80PLUS Gold Modular Fanless Power Supply
http://feedback.ebay.ca/ws/eBayISAPI...onthelam7&iid=
http://heatware.com/eval.php?id=44147
Ps3 -> Dvr Hardware Canucks Press Releases & Tech News 4 May 14, 2008 07:58 AM
Access motorola pvr/dvr killerklown Off Topic 0 March 15, 2008 12:43 PM
