-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   HTPC + Harmony one (http://www.hardwarecanucks.com/forum/htpc-systems-software/19323-htpc-harmony-one.html)
martin_metal_88 June 26, 2009 11:48 AM
HTPC + Harmony one
Hi huys, now building a HTPC and I wonder if you know if it`s possible to make the Logitech Harmony one work with it? I can`t find on the web if it`s HF or RF. or both. Plz help me guys it would be a realy good add to a gamer HTPC.
Ask for more
JD June 26, 2009 08:41 PM
You'd have to have a Media Center IR receiver, or some other IR receiver in the HTPC. Then you could use the Harmony One with it fine.
If you get a Media Center compatible one though, it's less programing hassle since Logitech has it in the database.
Dazmode June 26, 2009 08:53 PM
I use Harmony One with Antec Fusion case.
martin_metal_88 June 27, 2009 05:00 AM
Ok so if I understand there is IR receiver wich are specially made for MC. I'll take a look at this if you have some to show me I realy like:P
Thx for fast answerguys.
Dazmode June 27, 2009 07:14 AM
http://www.tomshardware.com/reviews/...case,1760.html
Yes, Fusion 430 comes with IR receiver.
Supergrover June 27, 2009 08:47 AM
Or if you already have the case or a different case in mind you can pickup one of these and just use the IR receiver.
NCIX.com - Buy Pcusa Vista Remote Control with IR Receiver Silver - HA-IR-01SV In Canada.
martin_metal_88 June 27, 2009 04:23 PM
Thank's you guys. all advise is realy apreciated. I think I will go the with supergrover one because I already have a Silverstone Lascala 17. HWC is the best place to get everything needed.
Ask for more
