Old May 5, 2009, 04:04 PM
grinder's Avatar
not to insult but as a troubleshooter i am inclined to ask... did you reboot your router?
Old May 8, 2009, 07:04 AM
HaDeS
Guest
Posts: n/a
Originally Posted by grinder View Post
whats the OS of the HTPC? Double check the DNS settings on the HTPC... if all else fails, hard-code the DNS of the HTPC to point to your ISP's DNS servers and see what happens. Can you ping out? ie. ping 74.125.127.147 instead of www.google.ca <?>
agreed... lock in the ip and dns. Else you can save the router config and then reset the securities to default and see if you can even connect... go back to basics before doing advanced connections.
Old May 8, 2009, 12:16 PM
BrainEater's Avatar
I've got both wireless routers , and wifi cards if yah wanna swap stuff around...
Intel 3930k /rIVe/32 Gb vengeance LP/3x eVGA 580's/Intel 520's/WD raptors/etc...
[FS] Yukon Trooper's FS Thread - Linksys WMP54G 802.11g Wireless NIC Card YukonTrooper Buy/Sell & Trade 51 March 2, 2009 03:50 PM
COD 4 problem... again... ARGH! shayan288 Gaming 0 January 16, 2009 05:14 PM
Network card/wireless adapter Inik Networking 5 January 13, 2009 04:31 PM
30GB Navy Blue Zune, Wireless PCI Card, A4Tech X7 Mouse, and Logitech Kb/mouse combo arekieh Buy/Sell & Trade 5 November 2, 2008 03:56 PM
Connecting PC to a HDTV. werty316 Display Units 3 April 7, 2008 05:22 PM
