Old June 14, 2007, 08:55 AM
cdn_Madrach's Avatar
Default Mobo
I'm looking at getting this matx Abit board for a htpc. Any comments or recomendations would be appreciated:) Keep in mind though I don't want to spend a fortune lol.
http://www.ncix.com/products/index.p...nufacture=ABit
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old June 14, 2007, 10:21 AM
sswilson's Avatar
I was looking at this board on a local site just the other night.
Not too many onboard video boards out yet that have an actual HDMI out, but a quick look reveals one glaring issue......
There's only one PCI slot, so forget running a second TV card (Unless you pick up an AIW, and I'm not too sure they're making them with the newer vid cards), or a high end sound card, or a PCI wireless nic, etc........
I don't think I'd buy any motherboard that was going to have all of its slots filled the second I installed it in the case.
Old June 14, 2007, 12:29 PM
Good points Wilson...but I was considering pcie tuner cards:) They do make them(pcie tuner cards)now don't they?
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Old June 14, 2007, 06:27 PM
sswilson's Avatar
I've yet to see any cards that run off of the PCIe X1 slot.
That doesn't mean that they don't exist, but I haven't seen or heard of anybody using one......
Old June 14, 2007, 07:24 PM
sswilson's Avatar
Well, what do you know.........
http://www.ncix.com/products/index.p...ture=VistaView
A little pricey though...........
Old June 14, 2007, 08:16 PM
Misoprostol
Guest
Posts: n/a
The Saber's a good card though. It's Vista compatible (go figure) and doesn't actually put out that much heat. I ended up with an ATi Theater 650 anyway since my mATX board in my HTPC has its PCIe slot taken up by the video card.
Still if you don't already have this mobo, I would look at the Biostar 690G. Solid little board. Put together a system for my friend around this mobo.
Old June 15, 2007, 06:41 AM
Thanks Misoprostol...but I need a socket 775 board. That is a nice board and just what I'm lookin for but AM2:( Oh well I'll keep looking for a bit. The only thing holding me back from ordering the Abit is that like Wilson said it only has 1 pci slot....but since there are pcie tuner cards hmmmm.....decisions, decisions lol.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Old June 15, 2007, 07:08 AM
grinder's Avatar
any time you can avoid using ATI and HTPC in the same box, please do.
that is my only suggestion.
Old July 6, 2007, 05:51 AM
Cheator's Avatar
Can I ask why that is? My ATI 550 pro works great, and when I had the x1600pro in there, it had incredible image quality (and i bought it for 30 bucks!). The only downside is that you can't run it with LinuxMCE.
Which mobo should I buy? yycraven CPU's and Motherboards 27 January 15, 2008 07:31 PM
Mobo and DVD DSNB Troubleshooting 6 December 27, 2007 06:08 PM
Bad cpu/mobo for o/c? Frustian Troubleshooting 6 November 3, 2007 10:09 PM
Which CPU for this mobo jap333 CPU's and Motherboards 12 October 24, 2007 02:26 PM
new mobo and ram help tony the tiger CPU's and Motherboards 6 September 19, 2007 06:24 PM
