Old March 27, 2009, 11:03 PM
Mr. Gruntsworthy's Avatar
Once again, i'll plug the Antec Minuet 350. So far as I know, it's one of the smallest desktop chassis around, as well as being sleek, stylish, and fitting for an HTPC case... as well, my experiences with Antec Cases have shown me that they are VERY easy to work with (Antec 900's shoddy cable management notwithstanding).
I actually have a slightly older Antec Minuet 300 lying around; it's essentially the same case, but lacking an eSata port on the front. It's missing the PSU, but you can special order a Minuet 350 PSU for seventy bucks or so, and it'll fit. I'm selling the case for $30. :P You know you want it...
Case: CoolerMaster HAF 932
CPU : Intel i7-5820K 6-core @ 3.3GHz
RAM : 32GB DDR4 2400MHz (G.SKILL Ripjaws)
HDD : Main: 240GB SSD SATA2 (Intel) Storage: 3TB SATA2 (WD Green) Backup: 500GB External USB (Hitatchi)
GFX : Gigabyte GTX 970 4GB
PSU : 750W Corsair Modular PSU
MoBo: Asus X99-A
View : Acer H213H 21.5" @ 1920 x 1080 + random 4:3 monitor
Level/Game Designer, Programmer
I run Durham 3D Printing, an online 3D Print shop!
Old May 13, 2009, 10:28 PM
I got the Popcorn hour. Its an amazing little box, its quiet and the interface is really sweet. Plays everything.
Old May 15, 2009, 08:55 AM
lcdguy's Avatar
Originally Posted by SKYMTL View Post
Doesn't Popcorn Hour do pretty much everything a HTPC can?
About the only thing the popcorn hours can't do are the following. (i have the first version so some format support may have changed)
1. Playback of OGM contrainers
2. TV Tuner
I have had my popcornhour for about 1 1/2 years. And it is so much better than any HTPC since all you do is plug it in. Add a windows share or stick a usb drive onto it. Then play your media.
I am really tempted to get the B variant motherboard so i can hook up my 2 1TB drives and stick it in a micro ATX case.
Possible HTPC build lcdguy HTPC Systems & Software 29 November 18, 2008 11:42 AM
HTPC build help? 3.0charlie HTPC Systems & Software 11 October 4, 2008 02:14 PM
Yet another HTPC build- help? misterd HTPC Systems & Software 4 August 1, 2008 10:10 AM
HTPC Build Phobia HTPC Systems & Software 15 July 16, 2008 10:07 AM
Looking to build a HTPC? Babrbarossa Press Releases & Tech News 0 February 16, 2007 11:51 AM
