-   HTPC Systems & Software (http://www.hardwarecanucks.com/forum/htpc-systems-software/)
-   -   Can't get FLAC files to work properly (http://www.hardwarecanucks.com/forum/htpc-systems-software/15780-cant-get-flac-files-work-properly.html)
biff March 14, 2009 02:20 PM
I'm having trouble getting flacs to work properly in VMC, they don't work properly in WMP either. I've followed I don't know how many online guides and none of them solve my problem. The files will play fine but are all showning under one huge album and not as they are laid out in their directories by artist/album/song name.
Has anybody gotten this to work? How did you do it?
cadaveca March 14, 2009 04:28 PM
Winamp plug-in.
biff March 14, 2009 07:43 PM
Not sure what you mean... I googled winamp as a plugin for VMC and didn't find anything. Could you be more specific?
cadaveca March 14, 2009 07:47 PM
use winamp, with FLAC plug-in. Don't use VMC myself, so I'm lost helping you there...
biff March 15, 2009 09:31 AM
Thanks. I got it going anyway... turns out one of the plugin's I was using that I got off one of the guides wasn't the latest version. Got the latest version and it worked better. Of course now it's a little choppy navigating the music menu with the remote and sometimes locks the system while playing a flac. Could be all the bastardizing and reg patches that were applied along the way.
