Old March 14, 2009, 09:47 AM
biff's Avatar
Default Sound cards vs. onboard optical audio
I still can't make up my mind what I want to do for audio with my HTPC setup. I've been looking at sound cards and using the analog out and there seems to be a very broad opinion of any hardware on this front. My receiver doesn't have HDMI input but I'm not sure I need it anyway. I really have two choices to get sound to it, either analog or go optical and use the receiver's DACs.
Does a dedicated sound card have any advantages over on board when talking about optical? My initial thoughts are no, since I would think the signal sent over the optical should be bit for bit the same sound data that a dedicated sound card or external DAC would get.... after all that's the point of it isn't it?
My receiver is a HK AVR-235. My main concern is music quality and a distant second is 5.1 for movies. I realize I may not get HD audio when watching blu-rays but from looking at the specs it appears that standard sound is near CD quality anyway and it is only for movies so I'm not sure I'd notice (or care) about any difference there anyway.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old March 14, 2009, 09:54 AM
vulcan500rider's Avatar
As far as I understand it, optical is optical, as one way or the other it offloads all the decoding to your receiver, so if you're leaning that way, I would stick with onboard.
As for choosing between the two, I always go digital over analog if I have the option; you don't have to worry about your computer handling the decoding, there's no signal degradation, and it's one simple cable. That's just my opinion, of course.
Old March 14, 2009, 10:29 AM
"Quote This..."
I second Vulcan.
Black belt in CAPS LOCK.
Old March 14, 2009, 10:47 AM
JD JD is offline
Well depending on the sound card, you could get features like DTS Connect and Dolby Digital Live in which case all your stereo sound would be upmixed to 5.1 DTS/DD before being sent over optical/coax.
Otherwise it would be the same as onboard, just sending out the exact audio format over optical/coax.
Old March 14, 2009, 11:39 AM
HaDeS
Guest
Posts: n/a
Optical ftw. Use the reciever dude.... sound is heaps better.
Old March 14, 2009, 12:29 PM
For the most part analog sounds better than digital because its up to the receiving end with optical to decide the end sound not the sound card.
If you output optical to a $50 receiver with $10 speakers it'll sound bad :P
Old March 14, 2009, 01:14 PM
biff's Avatar
Well it's a Harmon Kardon AVR-235 receiver, which from what I gather HK is pretty good stuff. And my speakers cost me ~1k in parts (for the L&R mains) so they're not cheapies either so I kinda have high hopes.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
Old March 14, 2009, 01:24 PM
HK stuff from places like Future Shop and so forth is "ok" equipment but nothing compared to the older stuff simply because HK is now so mass produced.
But yes with that setup you'll be fine.
No sound off my Onboard or my soundcard Shadowmeph Troubleshooting 3 February 27, 2009 04:37 PM
750i FTW Onboard Audio Problem kragnorok Audio 2 February 8, 2009 08:36 PM
Audigy 2 value or DS3L onboard audio? donimo Audio 17 January 16, 2009 04:19 PM
Onboard Audio versus Soundcard mazabe Audio 10 May 9, 2008 05:21 AM
Creative Sound Blaster X-Fi Xtreme Audio is not really a X-FI sound card dirtfarmer Audio 15 January 2, 2008 07:15 PM
