Old March 18, 2009, 06:49 PM
I would go for the 4350 if I were you. According to this review:
AnandTech: ATI Radeon HD 4350 and 4550: Great HTPC Solutions
It says that while the 4350 and the 4550 both support full hardware decoding of a 1080p video the 4350 can not handle 2 simultaneous video streams. So if you want to use picture in picture the second video stream will have to be handled by your CPU.
And, no a x16 PCIe 1.0 slot will not bottleneck a 4350 or a 4550.
Old March 18, 2009, 09:20 PM
Mr. Gruntsworthy's Avatar
wait, you're confusing me... you tell me to go for the 4350, but then tell me it's at a disadvantage to the 4550...
I think you made a typo
MAIN RIG:
Case: Antec 900
CPU : Intel E8400 45nm Core 2 Duo @ 3GHz 1333MHz FSB
RAM : 4GB DDR2 800MHz (OCZ Platinum)
HDD : Main: 120GB SSD (OCZ) Media: 500GB (WD) Storage: 1TB (WD)
GFX : HD4850 (512MB)
PSU : 610W PC Power Silencer
MoBo: Asus P5Q SE
View : Acer H213H 21.5" @ 1920 x 1080
Oshawa Deathmatch Community -- An open group for Durham/Toronto Airsoft, Paintball, and Nerf players. Come join!
My Game Dev website: http://mikeseguin.webs.com/
Old March 19, 2009, 01:59 PM
It depends what you're going to be using the card for. The only real place that the 4550 has an advantage with is with picture in picture (PiP). With some of the new blu-ray titles coming out you can have a little box in the corner of the screen with a different video. Normally this is used for the director's commentary or something equally silly. If you think that you are going to take advantage of that then you should probably buy the 4550. If you don't use PiP then I would recommend the 4530.
Reading the wikipedia page on PiP I notice that it says that most new blu-ray titles use Standard Definition video for the extra content. So it seems that the 4550 would be a bit overkill even if you used PiP. Because if there is only one HD stream (the actual movie) the 4350 would decode that and then your processor can easily handle the secondary SD stream.
Old March 19, 2009, 05:12 PM
Eh, I might as well go with the 4550. Minimal price increase for the better card seems like an okay tradeoff... the 4550 is what I'm settled on.
MAIN RIG:
Case: Antec 900
MoBo: Asus P5Q SE
Old March 19, 2009, 07:58 PM
If you can find a passive 4550 then I would say go for it but if you can't I would go for the completely silent 4350
Old March 19, 2009, 09:32 PM
The 4550 I'm looking at has a small blue heatsink on it with a fan. I'm sure it won't make that much noise... remember, I'm used to my Xbox 360, lol. That thing sounds like a friggin vacuum cleaner.
MAIN RIG:
Case: Antec 900
MoBo: Asus P5Q SE
Old March 22, 2009, 09:50 PM
I've come bearing an update:
I've decided that I may not want to keep with the stock heatsink that I have on my E4600 downstairs (which is the chip I'm putting in my HTPC). The case is going to be small, so I want something with a little more cooling power, but that fits in such a small case. I've decided on the 'Zalman CNPS8700.' It's made for low-profile cases like the Minuet, and looks like it'll do a good job of cooling my chip amidst the warm atmosphere that'll be inside my HTPC...
thoughts/suggestions on other low-profile HSF?
MAIN RIG:
Case: Antec 900
MoBo: Asus P5Q SE
Old March 22, 2009, 10:10 PM
Would this be too big?
Noctua NH-U9B LGA775/AM2/AM2+ Heatsink 4 Heatpipe Cooler W/ NF-B9 Fan & Thermal Paste - DirectCanada
  #19 (permalink)
Old March 23, 2009, 05:06 AM
Yes... the case is a low-profile, slim Antec Minuet 350.
MAIN RIG:
Case: Antec 900
MoBo: Asus P5Q SE
  #20 (permalink)
Old March 27, 2009, 10:58 PM
Update: Today I bought meself a brand new Antec Minuet 350. Pics to come sometime today. (I'm actually going to start a thread in the Worklog section later)
Does anybody know if the Minuet 350 PSU can fit into the Minuet 300 chassis? So far as I know, the 350 is just an updated version of the 300 (much like the Antec 900-II).
Cuz I gots an extra Minuet 300 case, and If I shove a special-ordered 350 replacement PSU in there, I can have the beginnings of a second HTPC to sell off.
MAIN RIG:
Case: Antec 900
MoBo: Asus P5Q SE
New HTPC build FrankyG HTPC Systems & Software 3 December 4, 2008 05:02 AM
HTPC build help? 3.0charlie HTPC Systems & Software 11 October 4, 2008 02:14 PM
Yet another HTPC build- help? misterd HTPC Systems & Software 4 August 1, 2008 10:10 AM
HTPC Build Phobia HTPC Systems & Software 15 July 16, 2008 10:07 AM
Looking to build a HTPC? Babrbarossa Press Releases & Tech News 0 February 16, 2007 10:51 AM
