Old February 21, 2009, 12:59 AM
Default Silverstone LC20
This may sound silly, but I can't find the exact answer anywhere. Will this case fit a GTX 260 in it? I have one laying around now that I bought my 295 and figured I may as well put it to good use
Intel Q6600 Asus Striker II Formula
OCZ Reaper PC-8500 EVGA GTX 295
Western Digital Velociraptor Samsung 2493 HM
Watercooled CPU & GPU Saitek Eclipse II
Logitech G5
Windows Vista Ultimate 64 Bit
Old February 21, 2009, 05:54 AM
Eagle Eye's Avatar
It will work provided there are no drives in the middle HDD cage, I further recommend removing the cage for more room if need be. Be mindful that the GTX260 is a pretty hot card so ensure that you have adequate cooling.
Regards,
EE
Old February 23, 2009, 10:27 AM
Perfect, thanks for the info Eagle Eye
Logitech G5
Old February 23, 2009, 11:00 AM
I guess they have different revisions of this case. My LC20 only has 1 cage and the drives are vertical. With my 4870 I can fit 5 drives in there instead of 6.
Laptop - Eurocom M5 Pro
Server - Xeon 2695v3 / 64GB DDR4 ECC / 512GB SSD - Host drive (Server 2016) / 1TB HP ex920 NVME SSD - VM Drive / 54TB Drive Pool
Old February 23, 2009, 11:31 AM
Yeah, I've noticed that too, there's the seperate cages you see, then there's the vertical mount cage with sound dampeners, but if you can fit a 4870 in there, I'm thinking that my 260 will fit as well, hopefully not too snug though
Logitech G5
Old February 23, 2009, 03:33 PM
It is a tight fit with the stock cooler and 5 drives but it does work.
Old February 23, 2009, 04:15 PM
How would you think it would fit with an HR03 GTX cooler mounted?
Logitech G5
Old February 24, 2009, 04:42 AM
Conky's Avatar
I have a simular silverstone case the gd1 and I had to modify the drve bay cage because of the length of the gtx 260. Also because of the top mounted power connectors on the video card, i also installed a 92mm fan in the drive bay cage wich reduced the temperatures quite a bit. hope this helps
1. Zalman 501HTPC, Maximus III Formula, i7 875K, Mushkin Chronos 120 deluxe, Mushkin Blackline 2x4 1600mh, Seasonic 650 Gold, XFX 6870 Black Edition,Samsung 22x, Windows 7 Home Premium 64X
Old February 24, 2009, 04:08 PM
That's a great idea, I think I'll buy it and see how it goes, an extra fan either way is a good idea all in all
Logitech G5
Old February 25, 2009, 04:58 AM
Conky's Avatar
You can mount 2 92mm fans in the drive bay cage. I had the gtx 260 in my Silverstone htpc case with 2 92mm fans and the internal temps of the case were ok. But I found that my rig runs alot cooler with the nmedia htpc because of the perferated top to allow better airflow. The Silverstone case is better quality with better construcion however the nmedia htpc allows for 2 120mm fans with one of the fans about 3 inches from the video card now that gtx temps are 10 degrees cooler about 41 celceus and also keeps the southbridge cool. I would suggest that you look at the nmedia htpc as well as the silverstone.
His 4870 + Trad2 + Lc20 = work? Cypher^64 Air Cooling 5 February 19, 2009 10:49 AM
Silverstone TJ07 Cadence Cases 5 December 3, 2008 09:03 AM
FS: Silverstone Zeus 1200W zlojack Buy/Sell & Trade 10 November 16, 2008 10:05 PM
Silverstone Kublai? born2expire Cases 6 September 8, 2007 04:59 AM
