Old March 20, 2009, 02:48 PM
Realityshift's Avatar
I managed to get everything working on my 9800GTX+, with the realtek codec I had to set it to HDMI out put as the default sound device. I also had the SPDIF patch cable in backwards >.<
The Builders Hammer
Old March 21, 2009, 07:48 PM
HI did all of the above including install of all the latest realtek drivers but no sound except through digital coax. I thaught of uninstalling all drivers and reinstaling.
Old March 31, 2009, 09:12 AM
lcdguy's Avatar
not sure if this counts or not but i was able to get 5.1 output on my hdmi connector. But there are a couple caveats.
1. It's an onboard HDMI port so i am not if this applies to hdmi over dvi.
2. MKV's still get no love
I did the following to get mine to work in sage tv.
1. Installed Nvidia Pure Video, Configured the audio to output to spdif.
2. Installed K-Lite Mega Pack
3. Set sage tv to use the dvd decryptor as the one included in the codec pack and the audio to the nvidia one.
DVD's - 5.1 audio works
ATSC - 5.1 audio works
MKV - 2.1 audio works, 5.1 doesn't.
Old March 31, 2009, 07:01 PM
HaDeS
Guest
Posts: n/a
Originally Posted by lcdguy View Post
I have tried to get this to work before. Granted it was on an ati based card. The most i could ever get to work was 2 channel sound. 5.1 never worked properly. If it were me and your computer has either digital coax or toslink fiberoptic just use that and save the headache.
You would need 3rd party software for 5.1 sound...
Old April 1, 2009, 07:16 PM
JD JD is offline
Try using AC3Filter? Should work I'd think. As long as you can disable all the other AC3/DD/DTS audio codecs you have.
Old April 1, 2009, 07:17 PM
lcdguy's Avatar
tried and could never get it to work properly with DTS streams. DOLBY works fine never got any love from DTS.
No HDMI sound from my P5E-VM biff O/S's, Drivers & General Software 2 January 8, 2009 07:45 PM
WTB: Video Card/Sound Card/Hard drive - Look here if u gotz some ! Flintblade Buy/Sell & Trade 4 December 4, 2008 10:27 PM
LF-Cheap ATI video card that can output sound through HDMI. Gunner86 Buy/Sell & Trade 9 November 2, 2008 06:19 PM
Auzentech X-FI HT 7.1 HDMI card pics and specs Robscix Audio 14 November 1, 2008 04:31 PM
Creative Sound Blaster X-Fi Xtreme Audio is not really a X-FI sound card dirtfarmer Audio 15 January 2, 2008 08:15 PM
