Old October 28, 2009, 09:03 AM
lowfat's Avatar
Originally Posted by Lima View Post
What does STB stand for?
set top box
Set-top box - Wikipedia, the free encyclopedia
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old October 28, 2009, 10:31 AM
Lima's Avatar
Aha. So... the STB's suck, or the tuner cards?
Old October 28, 2009, 11:02 AM
lowfat's Avatar
Well if you use a STB you can't use a tuner card. You need a capture card. And yes they are all pretty bad at the time. It is better to go w/ a PVR from by your cable/satellite provider.
Queen of Dreams WIP
Big Lian Li
Complete
Old October 28, 2009, 11:19 AM
Lima's Avatar
Just realized something. Gonna go see what hapens when I plug my TV in without the STB, then I'll know what I'll need to do this. BBL
Old October 28, 2009, 01:03 PM
Lima's Avatar
I'll be ok with just a tuner in my pc for now. All the chanels I want are still available straight from the wall.
What's wrong with the capture cards, where do the fall short? With the STB doing all the decoding, how could they fail in the process of bringing the picture to the PC's monitor? Or, is it the software that sucks?
using my HDTV as a monitor. Bucklaz Display Units 11 December 28, 2008 01:36 AM
HDTV image cuts out howettl Troubleshooting 1 August 2, 2008 02:21 PM
PCTV HD Pro Stick HDTV Tuner ?? frosty Peripherals 0 April 13, 2008 05:04 AM
Connecting PC to a HDTV. werty316 Display Units 3 April 7, 2008 05:22 PM
How to hook up to HDTV? LegendofJubei Display Units 15 December 8, 2007 12:02 AM
