Old December 27, 2008, 09:24 AM
Default Will the following setup play 1080p Mkv
Hello, im planning on building a HTPC for my living room... my question is if the following will play 1080p MKVs and blu rays...
Gigabyte GA-MA78GM-S2HP AMD780G mATX AM2+ PCI-EX DDR2 SATA2 RAID Video Sound GBLAN HDMI
NCIX.com - Buy Gigabyte GA-MA78GM-S2HP AMD780G mATX AM2+ PCI-EX DDR2 SATA2 RAID Video Sound GBLAN HDMI Motherboard - GA-MA78GM-S2HP In Canada.
AMD Athlon 64 X2 6000+ Dual Core Processor AM2 3.1GHZ 2X512KB Cache 89W 65NM
NCIX.com - Buy AMD Athlon 64 X2 6000+ Dual Core Processor AM2 3.1GHZ 2X512KB Cache 89W 65NM Retail Box - ADV6000DOBOX In Canada.
2gb of 6400 RAM
and a mATX case
The mother
board comes with an integrated ATI 3200, hopefully that should be enough...
Thanks
Old December 27, 2008, 11:57 AM
JD JD is offline
I don't see why not...
My AMD Athlon X2 4400+ (Socket 939) with a 7900GTO (no HD decoding on that) can play them fine. Might want to use CoreAVC for lower CPU usage, but ffdshow works fine too.
Old December 27, 2008, 12:10 PM
Cheator's Avatar
gpu might be the only problem. But i would guess it would be ok
Optimus: Antec P180, Asus P5Q-E, E8400, 4 GB RAM, Asus 4850, Seagate 320gb, Antec TC II
Teletraan I: Asus P5K-E/WIFI, E4500, 2 GB RAM, ATI 3450, Sapphire Theatrix, 2.25TB storage, Antec SP2 400w
Galvatron: Asus M2NPV-VM, 3800+ X2, 2GB RAM, NV8500GT, Seasonic 500w
Tracks: Acer AS5920, C2D 2.1ghz 45nm, 3GB DDR2, NV8600m GT, 250gb hdd
Hound: Gigabyte GA-MA74GM-S, AMD 4400+ X2, 1 GB RAM, 2900XT, 500w Seasonic
My Heatware!
| Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old December 27, 2008, 12:28 PM
misterd's Avatar
They play fine, i have the same motherboard and a AMD 5000+ Black 2.6Ghz. No dropped frames that I noticed.
| i7 920 / Noctua NH-U12P / Asus Rampage 2 Extreme / 24GB Corsair Vengeance / Asus HD5870 / Corsair 600T / Corsair HX850 / Intel 520 240GB |
| X2 5000+ BE / Passive Scythe Ninja Mini / Gigabyte MA78GM-S2H
/ 4GB G.Skill Pi / Fractal Core 3000 / Corsair CX430-M / Intel X25-M 80GB |
| i7 2700k / CM 212+ / Asus P8Z68 Pro-M / 8GB Corsair Vengeance / Antec SLK3700AMB / Seasonic M12-II 430W / Samsung 1TB |
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old December 27, 2008, 07:09 PM
Silvgearx's Avatar
looks
My E2180 at stock 2.0ghz plays 1080p MKV files at 20%-50% max , GPU usage 1%-6%
Media player classic- homecinema used with coreavc codec. (the coreAVC saves about 2%-5% cpu usage )
With MPC-HC you can make your supporting 2xxx 3xxx 4xxx series to off load cpu usage , of course the files got to be h264, i follow this guide and made drop the cpu usage to 10%-30% and upped gpu usage to 14% but when you want to skip it has some delays like a second or two.
for HTPC's its good to get power saving components
Old December 27, 2008, 09:00 PM
CanadaRox's Avatar
I have that exact motherboard with a slower processor and it can play 1080p perfectly. I don't know the CPU usage exactly, but it is fairly low as the GPU does most of the work.
Project: Black and White
Old February 3, 2009, 06:31 AM
Skyllz's Avatar
In the same vein, would a LGA775 P4 3.0ghz with 2 gig and a 7600GT be able to pull it off? I would only need a new mobo to stuff that into a micro ATX case. I got the rest somehwere in my parts bins.
PC Cyber Canada - For All Your Computer Needs for mobo maybe.
Strictly to play 720p/1080i in stereo(MKV and such), mainly TV shows.
Is smoke supposed to come out of there?
Old February 3, 2009, 06:41 AM
"Quote This..."
My amd 3800+ Asus m2n-hdmi HTPC barely plays 1080p. Had audio sync issues until I told zoomplayer to drop late frames. Does 720p just fine though.
Old March 6, 2009, 07:12 PM
gingerbee's Avatar
just dealing with core2 my rule of thumb is 720p needs min 1.6 ghz 1080p needs 2.4 thats not using an off loading codec like power dvd or coreavc all other ones i have tried do not off load
1080p Projectors under $1400!! Cptn Vortex Display Units 11 January 8, 2009 12:30 PM
1080p LCD Monitors? nexus1111 Display Units 4 December 5, 2008 03:59 PM
1080p Phobia Troubleshooting 7 July 4, 2008 11:00 PM
