Hi, the picture from my ATI tv tuner is blurry do anyone know how to fix it? There is an app in my control panel called ATI TV config. I read online that you can use it to clear up the picture do anyone know what settings I should use to do that? (See link for pictures of the settings in that control panel app.) The card is a Diamond TV Wonder 650 |
I think using noise reduction would make it even more blurry since to remove noise, it blurs the image. Might want to look at the comb filter settings instead I'd think. Could you post some screenshots of TV shows too? Might help others figure out what's causing it.
__________________ Xeon Quad X3350 | 3.40GHz (Damn X38 chipset) ASUS Maximus Formula | BIOS RF0410 2GB Corsair Dominator | 850MHz [/font]4-4-4-12-2T 2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T HIS ICEQ4 Turbo HD4850 @ 700/1200 X-Fi XtremeMusic Antec TruePower Quattro 850W Antec 900 [ HEATWARE ] |
I am new at this so how so I get a screenshots of TV shows? when I try the screen appears black How do I get resolution scaling? Quote:
Oh ok thanks, my uncle works for a Cable company and he said it could be due to the fact the same drop line is split between my tuner, and the cable modem for my internet. What do you all think about this being the cause?
Mine is setup exactly the same. Before I built my new rig I was running two tuners and had Picture in Picture and had great picture and fast net speeds. Get yourself the newest drivers for your tuner and try out KM player... If you need some help configuring post back. There are other TV applications that are great also, VLC player, Chris TV..etc. Most of these types of tuners will require you to set them up manually though. No big deal once you understand what is what, it is quite easy. |
The issue at hand is that the TV broadcast you are displaying is 320x240 or 720x480, and when displayed into a pc monitor, at say, 1860x1050, there just is not enough pixel info for a clear image. To overcome this, you need software that will "scale" the image and create that extra pixel info acccurately. Try some of Rob's suggestions, for me it's a matter of personal preference as to what you use.
| Thread Tools | |
| Display Modes | |
